87 F-150 Clutch Noise (squeal)
Old 09-21-2002, 01:09 PM
Brian Wilson's Avatar
Brian Wilson
Brian Wilson is offline
I have an 87 F-150
Had the clutch replaced appx. 3 months ago.
When my truck gets warmed up, there is a high pitched squeal that only goes away when I press in my clutch pedal.
When I let it out it comes back.
Is this something my repair shop should have fixed?
What should I look for in terms of getting this fixed now?
Thanks in advance...
Old 09-21-2002, 04:24 PM
jeff21876's Avatar
jeff21876
jeff21876 is offline
Old 04-13-2015, 07:03 PM
pyleketerson's Avatar
pyleketerson
pyleketerson is offline
Nice, a bump from 13 years ago. Having trouble searching out this particular issue on my 1987 F-350.
Quick background. Burned up my clutch over the winter plowing our road. Never had a squeal. Mechanic replaced the burned up clutch with a new one...then we have a squeal (which goes away when clutch is pressed in). After some head scratching, mechanic replaced the new clutch with another new one. Driving home from picking it up, same squeal.
Before calling my mechanic tomorrow, was hoping someone might have come across this issue. Thanks.
Old 04-13-2015, 07:07 PM
pyleketerson
And I'm no mechanic so I apologize for the lack of technical details. Learning as I go here. Any input would be appreciated!
Old 04-13-2015, 09:14 PM
krooser's Avatar
krooser
krooser is offline
Bad throwout bearing?
Old 04-13-2015, 09:38 PM
pyleketerson
That's what we thought too, and it was replaced.
Old 04-13-2015, 11:57 PM
pyleketerson
I just noticed tonight if I press the clutch pedal in about one inch without disturbing RPMs, the squeak goes away. There is a little bit of play in there, and the pressure is being put on something which isn't reacting right...
Old 04-15-2015, 06:00 PM
PRIMERED79 SHORT BED's Avatar
PRIMERED79 SHORT BED is offline
Did they replace the clutch fork?
I ask because I had a clutch installed three months ago, flywheel,new clutch kit with throw out bearing and pilot bearing,new clutch fork, slave, and master cylinder all new fluid.
And about a month ago it was starting to squeal too.
Push the clutch pedal in just a hair and it stops. I know its the throw out bearing, but I was wondering about spraying some lube on it to keep it quiet.
Anybody know if that will help and not hurt the clutch disc?
Old 04-15-2015, 10:12 PM
pyleketerson
That's actually a really good question. I'll reply when I have found if he replaced the clutch fork.
Old 04-16-2015, 04:43 PM
pyleketerson
The clutch fork was not replaced.
It was also suggested I look at the input shaft bearing. We'll be examining that tomorrow as well.
Old 04-16-2015, 06:44 PM
Dirt racer's Avatar
Dirt racer
Dirt racer is offline
If it's a hydraulic clutch there probably isn't a clutch fork. At least mine doesn't have one. 92 F150 4X4. I am thinking a bearing is bad. The one in the crackshaft in the middle of the flywheel.
Old 04-16-2015, 10:42 PM
Mine is a 92 four speed and has a clutch fork.
My squeak is coming from the throw out bearing.
Old 04-16-2015, 11:46 PM
FarmerJon's Avatar
FarmerJon
FarmerJon is offline
Mine is an 87 F250 460 4sp and it has hydraulic actuated clutch with an actuating fork .
Old 04-17-2015, 12:18 AM
^^^maybe that's what I have too.
I just always called it a clutch fork.
Old 04-17-2015, 09:56 AM
Mike1's Avatar
Mike1
Mike1 is offline
How much free play do you have in the pedal? You should have somewhere between 1/2" - 1" Max. If you're able to push just a little on the pedal and it goes away, I'd say it's no adjusted properly. IF after the system is fully bled, you should be able to adjust the rod, if your rod isn't adjustable then you should be looking at the bushings in the pedal.
With the truck running and in neutral, Does it squeal? If it does then it's in the bearing, hydraulics, pedal. If not and it only squeals when in gear and driving then you're more than likely looking at the transmission.
Quick Reply: 87 F-150 Clutch Noise (squeal)
