Did the work myself (only 3 calls back to Cary for questions), as for the parts I decided that I would go with new springs and sway bar from Ford. Worked out great - drives like a new truck, reallly pleased with the results!
When it was all said and done I paid a little over a 1200.00 at the dealer for the sway bar, springs, and sway bar mounting hardware. I figured that with all the work I was going to do the last thing I wanted was to mount up some trucks worn out "stuff", but I read where many others have gone with used parts with good results.
JMM,
Did you have to have a full sway bar assembly or did your model already have one ?
Didnt know which hardware I will need
I did not have one and had to buy one. The parts I picked up were:
BAR ASY-REAR STAB
Part #: F81Z5A772AA
Pack Qty: 1
SPG ASY-FRT
Part #: 2C3Z5310HA
Pack Qty: 2
SPRING ASY. (REAR)
Part #: 3C3Z5560CA
Pack Qty: 2
For some reason I do not have the rear stabilizer bar hardware but I remember that there were two flavors of saddle clamps and bushings - get the larger of the two
