Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Southwest Region > Arizona Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Arizona Chapter Join Chapter, Leader: Bill W
  #1 (permalink)
Old 08-01-2012, 06:16 PM
daddykitty's Avatar
daddykitty daddykitty is offline
Garage is empty, add now
daddykitty is gaining momentum as a positive member of FTE.
Bought an excursion yesterday
First off, props to this site, tons of info on here! I purchased a white 2005 excursion eddie bauer 4x4 with 148k yesterday, everything on it was in superior shape visually. I did notice on my test drive that there is a little play in the steering wheel, about 1-2" either way before you feel it turning...i am thinking maybe an alignment and they should be able to take out the lash in the gear box...is that right? After i drove it appx 40 miles....i stopped to fill it up, drove about 10 miles the the check engine light comes on. I read the code today and TADA PO401 faulty egr valve. So my question is, do i just delete it and save headaches or replace the valve? Valve is 204 at autozone and i have no clue what the price of a delete kit is and if i do delete it will i be able to go thru emissions in az? I will post pics as soon as i am able to. thanks for your help. i paid 15k for the vehicle CASH! autocheck score was an 87 btw.
Kyle
  #2 (permalink)
Old 08-02-2012, 11:04 AM
Bill W's Avatar
Bill W Bill W is offline
AZ Chapter Ldr
1963 Ford F-250
My Garage
Bill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputation
Bill Wilson
Sounds like a nice truck ! Sorry I can not help to answer any questions.... I don't know that much about newer fords
  #3 (permalink)
Old 08-04-2012, 06:05 AM
Redneckfordf2502002's Avatar
Redneckfordf2502002 Redneckfordf2502002 is offline
1997 Ford Expedition
My Garage
Redneckfordf2502002 has much to be proud ofRedneckfordf2502002 has much to be proud ofRedneckfordf2502002 has much to be proud ofRedneckfordf2502002 has much to be proud ofRedneckfordf2502002 has much to be proud ofRedneckfordf2502002 has much to be proud ofRedneckfordf2502002 has much to be proud ofRedneckfordf2502002 has much to be proud ofRedneckfordf2502002 has much to be proud of
www.facebook.com/trav.franitti
What engine is it and where are you located?
If you delete it you will have tons of emissions problems but if you are in the white mountains or flagstaff you don't have to worry about that.
Really that is a good deal for an excursion.
By the way our 97 Ford Expedition is pulling the same problem up and the egr valve can be cleaned if anything I would do that first clear the codes and then see what it does. I would be able to tell you more though if I knew the engine.
As for the steering wheel play I would think that would help if not I don't know what to say really.
Trav
__________________
Build thread for all: http://www.ford-trucks.com/forums/11...l#post12205190 1997 Ford Expedition 4x4, 1988 Ford F150 4x4, 2002 Ford F250 4x4, 1986 Ford F150 4x4, 1989 Ford F250 4x4,1984 Ford Bronco 2 4x4, 1973 Harley Davidson XLCH, 85 Chevy G20 Van, 89 f350 4x4 conversion: http://www.ford-trucks.com/forums/11...l#post11689018 PM for details on all
  #4 (permalink)
Old 08-04-2012, 05:48 PM
Nsaan's Avatar
Nsaan Nsaan is online now
2000 Ford Excursion
My Garage
Nsaan has a very good reputation on FTE.Nsaan has a very good reputation on FTE.Nsaan has a very good reputation on FTE.
It was a good week to buy Excursions I guess. I bought one too. Mine is a 2000 Limited 4x4 with the 7.3. 173k miles. for 7500bucks. It feels good to pay cash for a vehicle doesn't it!
Click the image to open in full size.
I am guessing from that yours is a 6.0 diesel. yes you can delete the EGR without running into emissions problems. What part of the valley are you in? I know the guys at Reliable Diesel in Mesa 480-325-6262 do them all the time on the 6.0's.
What front end does yours have. I have heard that the late model 05's have the coil spring front end. The guy I got mine from just put 1k into it chasing the same problems. He replaced the tie rods and the pitman arm on the steering box.
__________________
Donn
1999 F450 7.3, 4r100, 4.88 gears, Scelzi utility bed. 200K miles, 14K lbs.
1998 Dodge 2500 SLT, Quad cab, 4x4, Cummins, 5spd 35's
Hers 2000 Excursion Limited 7.3 4x4 4inch lift 35's
A.E. Domestic Bundle. (Ford, Dodge, Chevy)
  #5 (permalink)
Old 08-04-2012, 07:07 PM
daddykitty's Avatar
6.0L diesel...i live in the faaaaaaaaarrrrrr west valley in tonopah. the ball joints were TOAST. i had a shop replace them as i dont have all the presses and such to get them out. I had hell replacing my 01 dodge ball joints....swore i'd never do that again. I cleared the code after the egr replacement and it threw the same code again after 1 driving cycle, so i am guessing a blockage in the return tube??? this is by far the nicest ex i have seen and i have seen alot in the last 2 months of looking. play is not as bad after the upper and lower ball joints replaced both sides, but still there, more of a nuisance i would like the steering tight, but tie rods are in good shape. shocks are still good not leaking but look original so probably end of life or near it. any recommendations for front shocks out there? i asked the shop to take out the lash in the gear box after they replaced the ball joints, did an alignment so i am thinking they didnt do it and are going to try to tell me they did. i'll post some pics here as soon as i can, but trust me whoever owned this took care of it.
  #6 (permalink)
Old 08-05-2012, 03:15 AM
My Garage
You say Egr valve maybe a broken vacuam line or something. I am not familar with diesels so I don't know I am a gasser guy.
Trav
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
