Secret to re-installing door panels on '89 F150? - Ford Truck Enthusiasts Forums
Old 07-10-2002, 10:39 PM
Jim_Banville Jim_Banville is offline
Jim_Banville is starting off with a positive reputation.
I replaced the door speakers. It seems you have to slide the door handle through the panel first, then you must fight to pressure from the handle to slide the top of the panel over the metal door body. Problem is that the little metal clips that hold the rubber trim along the top edge of the panel catches on the door's metal body and bends the clips holding the trim and it comes loose I tried removing the door handle and re-installing it after the door panel was slipped over the door body, but screwing the handle back on with the door panel was in place was so close to impossible that I gave up! All the plastic door panel clips that hold the panel to the door body seem to grab their holes at all the wrong times Grrrrr!
Old 07-11-2002, 06:47 PM
Lookinfurfun Lookinfurfun is offline
Lookinfurfun is starting off with a positive reputation.
Take that rubber trim piece off.
Make sure that the plastic pieces(I think there are about 10) that hold the panel to the door are attached to the panel. Slip the door handle through the hole in the door panel. You may have to push up on the panel to get the top of the panel over the door lock rod. Now push at all of the places where the plastic pieces to hold the panel were. Everything should be pretty snug and you can now screw in the couple of screws and then add teh rubber trim piece.
Have fun.
-Anthony
Old 09-21-2002, 06:02 PM
dewey_gubbels dewey_gubbels is offline
dewey_gubbels is starting off with a positive reputation.
Does anyone have the part numbers for those little clips. I understand you need to replace them every time you remove the door panel. Thanks
Old 09-21-2002, 07:45 PM
Pastmaster Pastmaster is offline
Pastmaster is starting off with a positive reputation.
Any auto store has those clips. I buy mine at Autozone for $1.99 w/6
If you messed up the top window rubber, you can buy new ones at Ford for $12. I've had to replace a couple allready.
Old 09-21-2002, 09:00 PM
gamehunter gamehunter is offline
gamehunter is starting off with a positive reputation.
E Van Door Panel Removal JWA Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 6 01-01-2017 04:41 PM
Door Panel Removal JWA 1968-2013 Full Size Vans 21 05-20-2016 06:17 AM
Installation of Door Window's Part's Customcab 1961 - 1966 F-100 & Larger F-Series Trucks 29 11-24-2008 10:55 PM
Power Window Stopped - Motor Runs chrisbeery 1987 - 1996 F150 & Larger F-Series Trucks 6 04-27-2008 08:47 PM
Power Window Stopped - Motor Runs chrisbeery 1978 - 1996 Big Bronco 0 04-13-2003 02:12 PM
Tags
1989, 1993, 89, 96, clips, door, f150, fasteners, hold, panel, panels, place, removal, remove, truck, window
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
