TRANS TEMP..... - Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
TRANS TEMP.....
Old 07-31-2012, 09:01 PM
NWWADD NWWADD is offline
NWWADD is starting off with a positive reputation.
TRANS TEMP.....
When I pull the temp at times gets as high as 220. I do have a $5000.00 Trans. I do not allow the temp to get any higher (Royal Purple Trans Fluid).
I have 2 additional trans B&M coolers and the temp just goes up and up.
Any ideas on what I can do to get the temp down? I also have a ex large tran pan.
side note: I have the BANKS 6gun kit installed with 4" exhaust. I normally have the 6Gun set at 3 or 4 while pulling.
If someone with help is willing to talk I would like to talk. Typing sucks on my phone lol. My # is 360- Nine nine one-35 eight eight.
Thank you, Dan. Again thank you very much for your help.
Old 07-31-2012, 09:28 PM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is online now
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
How many coolers do you have all together? And what year is your Excursion?
Old 07-31-2012, 09:36 PM
2001 7.3. 2 B&M coolers in-line with the Radiator cooler, I believe.
Old 08-01-2012, 12:24 AM
mrad mrad is offline
mrad is gaining momentum as a positive member of FTE.
Dan ,
I recently installed a 26 row 6.0l cooler and replaced the by-pass tube at the same time time. My temps have dropped about 25-30 degreses on average pulling my 10,000 lb TT.
Old 08-01-2012, 09:02 AM
TXSailor's Avatar
TXSailor TXSailor is offline
TXSailor has a good reputation on FTE.TXSailor has a good reputation on FTE.
I installed a 26 row 6.0 cooler on my 7.3 and don't see anywhere those temps when I tow my 8,000 AirStream in the Texas Heat. Typically , it might hit 205 on a really ot day and a steep climb but most of the time it's about 190.
I'd check the flow rate as you may have a partial blockage somewhere .....
D
Old 08-01-2012, 01:36 PM
Swagtastic Swagtastic is offline
Swagtastic is starting off with a positive reputation.
D
My thoughts exactly
Old 08-01-2012, 05:36 PM
Toreador_Diesel's Avatar
Toreador_Diesel Toreador_Diesel is online now
Toreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputation
My thought is that 3 coolers though excessive is making things harder than they need to be....
As myself and others have done, get a 26-row 6.0 transcooler, drop it in, mod the lines and be done.
My trans stays remarkably cool during the hottest of Texas summers and really keeps the trans cooler when I tow.
I also noticed that you have a Banks tuner, I would highly recommend not towing in the higher settings as it's a great way to burn up your motor and trans. I would also highly recommend another chip aside from banks.
There are better chips out there that do a better job of tuning the engine and trans....
Gearhead Automotive Performance
Chips - Tuning - 1994.5 - 2003 Powerstroke 7.3L - Ford Powerstroke
http://www.totaldieselperformance.com/
Old 08-01-2012, 10:03 PM
Quote:
That might be too much restriction, which will cause the bypass to open. That will keep most of the fluid from going to the coolers.
You should run a flow test.
You need two containers, each about a gallon is fine.
Have a helper to start/stop the engine.
Remove the cooler line where it attaches to the rear of the transmission. Point the line into one of the containers. Have your helper start the engine. Once the flow is steady (just a few seconds) move the line to the second container for exactly 15 seconds then put the line back in the first container and shut the engine off.
If there is at least a quart in the second container it passes. If fluid comes spraying out of the transmission end it fails - the bypass is open. Now you would have to determine if it is a stuck bypass or a restricted cooler circuit. A little drip from the trans end is normal.
2004 6.0 F250 pillar gauge install AuerF250 1999 to 2016 Super Duty 3 04-07-2011 04:31 PM
Banks 6 Gun settings DSC450 1999 to 2016 Super Duty 1 01-22-2009 02:06 AM
Trans Temp, Do you trust yours? 02GrayPowerStroke 1999 - 2003 7.3L Power Stroke Diesel 21 07-12-2007 12:21 PM
Numerology ranger rules General NON-Automotive Conversation 22 10-11-2005 09:26 AM
Trans temp sensor giving fault code mchild Clutch, Transmission, Differential, Axle & Transfer Case 5 05-28-2005 06:44 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
