rust - fluid film vs ? - Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
Old 07-31-2012, 06:06 PM
cassenbl cassenbl is offline
cassenbl is starting off with a positive reputation.
Just bought 2004 Ex that came from Minnesota. Frame rusty with some flaking but not severe (think metal under is solid). Seems allot of members here swear by Fluid Film for frame rust. Others have used chain saw oil and other rust converters. What has everyone found to work the best? I live on gravel roads and question these and dust collection.
Your thoughts?
Ben
Old 07-31-2012, 09:27 PM
Red97350 Red97350 is offline
Red97350 is gaining momentum as a positive member of FTE.
I too am curious as I am in a very similar boat. I was thinking Ziebart, but I think that would be pricey.
Red
Old 07-31-2012, 10:03 PM
Sarasota Sarasota is offline
Sarasota is starting off with a positive reputation.
Same situation here. I elected to go with Black Star in aerosol form. I think I'm going to go with a gallon next and apply with a bug sprayer. Black star seems to be working well and living up to claims.
Old 08-01-2012, 07:39 AM
tdappleman tdappleman is offline
tdappleman is a name known to alltdappleman is a name known to alltdappleman is a name known to alltdappleman is a name known to alltdappleman is a name known to alltdappleman is a name known to all
I wanted the most protection I could get living at the coast. I cleaned the bottom with a strong degreaser and pressure washer and after it dried applied Rust Reformer. Has held up for over 3 years and the only area where surface rust is present is where the lift arms touch the frames for rotates, etc.
RustOleum.com
Old 08-01-2012, 09:05 AM
grishw1's Avatar
grishw1 grishw1 is offline
grishw1 is gaining momentum as a positive member of FTE.
Quote:
I've got blackstar under my truck and its worked great. Very easy to work with. Tried the bug sprayer as an application medium and it was kinda messy. You need a tip that allows it to come out very fine and the one I used was more like a stream, so it didn't work. I rolled and brushed mine on. Will buy the spray cans next time for the hard to reach areas.
Old 08-01-2012, 01:01 PM
Shepherd2 Shepherd2 is offline
Shepherd2 has a good reputation on FTE.Shepherd2 has a good reputation on FTE.Shepherd2 has a good reputation on FTE.
I just bought some Corroseal and so far it's looking pretty good. It only cost $52 for a gallon. I slopped it on with a brush and when it dried it was smooth, no brush marks at all. Another cool thing is that it dries clear over a painted surface.
Corroseal Rust Converter | Metal Primer | Rust Paint
Old 08-01-2012, 01:21 PM
Der ABT's Avatar
Der ABT Der ABT is offline
Der ABT is starting off with a positive reputation.
Been looking into this as well. Had been looking at rust bullet but now i see there are alot more options
Old 08-01-2012, 04:20 PM
Thanks everyone. Now I have lots of options.
Old 08-01-2012, 06:12 PM
Decided to go with Corroseal. I am no where an expert here but what I am finding it seems rust converters that work are basically tanic acid to neutralize the rust and a polymer to seal the metal after the acid converts it. As long as it has these two ingredients, they are basically the same. I went to a few marine sites (boats in ocean water would be exposed to more salt than my truck) and corroseal has very good feed back. Yes it would be better to sand blast down and then seal but I do not want to do a body off restoration. I am going to hammer loose rust off with hammer and wire brush, then pressure wash, let dry and then spray on with Wagner paint sprayer. We will see how it goes. Ordered Corroseal online from Home Depot 1 gallon shipped to me for $57.21.
Ben
Old 08-01-2012, 08:39 PM
grishw1's Avatar
I liked the blackstar because it goes on a milky white and dries matte black which for me was great because I'm putting it underneath my truck and wanted it black.
Old 08-02-2012, 04:59 AM
The Corroseal does the same thing. Goes on white, turns purple, then black. Must be a similiar formula.
Old 08-02-2012, 11:04 AM
outofcontrolreb outofcontrolreb is offline
outofcontrolreb is starting off with a positive reputation.
I used Blackstar on mine and it holding up
Fluid film and frame rust sudsmcduff 1999 - 2003 7.3L Power Stroke Diesel 30 10-30-2015 05:12 PM
For the rust belt guys. T diesel 1999 to 2016 Super Duty 10 12-03-2014 11:21 AM
Rust control using Fluid Film CPB1 6.0L Power Stroke Diesel 6 01-26-2014 05:35 PM
2001 F250 rust issues redbug 1999 to 2016 Super Duty 15 10-22-2011 01:55 AM
truck undercoating, rust proofing ??????? billy150 General Automotive Discussion 2 10-13-2009 07:31 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
