Lifter noise? - Ford Truck Enthusiasts Forums
Lifter noise?
Old 07-31-2012, 02:51 PM
limegoldf100 limegoldf100 is offline
limegoldf100 is starting off with a positive reputation.
Lifter noise?
Maybe this has been discussed before, but I have a 2002 Ranger 3.0 purchased 2 years ago on eBay. It was advertised as having lifter noise.
When I got it, it had a lot of noise at idle and at speed. I poured a lot of products through it (Seafoam, Lucas Oil, crankcase cleaner). Eventually, the noise disappeared. A couple of months later, it came back but different. Now, it's nearly silent at idle but gets much louder as it speeds up, particularly under a load.
I have had a couple of good mechanics listen (one cut his teeth at a Ford dealership) and he's sure it's lifters. Another is thinking timing chain.
Anyone with a similar experience? At 144,000 miles, it runs fine, burns no oil, has adequate power, but the sound is really annoying.
Old 05-25-2013, 10:31 PM
aswingerat44's Avatar
aswingerat44 aswingerat44 is offline
aswingerat44 is starting off with a positive reputation.
Ouch.
If it sounds like this it is probably a lifter rod.
On Exploded diagram ,# 11 is the suspect. I had a labor quote for $ 1700
to rebuild the whole engine.
2013-05-25_2028 - organians's library
roller lifters billyrayf150 Performance & General Engine Building 1 02-13-2016 11:50 AM
Lifter noise? tstory Modular V10 (6.8l) 8 10-20-2015 09:52 PM
"typewriter" noise showed up at 36k djjoshuad 6.7L Power Stroke Diesel 25 01-24-2015 11:30 PM
Lifter noise and harmonic balancer questions 73 fourxfour 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 8 02-25-2014 10:40 PM
Could it be collapsed lifters? The Fool On Th Hill 1967 - 1972 F-100 & Larger F-Series Trucks 21 02-25-2012 06:33 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
