rear end noise turning right
Is it like a re-re-re-re-re-re sound? I just replaced the clutch packs and spider gear in my 03 supercrew and had that problem. I had to add more friction modifier to get it to go away. It is the spider gears and clutches turning. Only Does it on turns. If you have recently changed the rear end fluid and didn't put friction modifier in that is your problem.
n.shift
1997-2006 Expedition & Navigator
08-27-2017 08:51 AM
DawnPatrol
04-09-2013 08:33 PM
