Which way to rotate the distributor?
Old 07-31-2012, 10:18 AM
part timing's Avatar
part timing
part timing is offline
96 F-250 5.8. Which way do you rotate the distributor to retard the timing?
Old 07-31-2012, 10:49 AM
Conanski's Avatar
Conanski
Conanski is offline
Counter clockwise when viewed from above.
Got a pinging problem? If you're gonna put a timing light on it don't forget to remove the grey spout plug in the ignition module harness(drivers side fender) to disable computer advance before setting the base timing. Factory is 10deg BTDC.
Old 07-31-2012, 11:27 AM
part timing
Thanks for the info!
Old 07-31-2012, 12:39 PM
jas88's Avatar
jas88
jas88 is offline
The rule is that you retard timing by turning the distributor in the same direction as the rotor turns. You advance timing by turning opposite the direction of the rotor.
sgauvry
07-29-2015 05:28 PM
RocketmanVT
12-30-2012 05:04 PM
Phantom
09-02-2004 04:26 PM
poacher
02-12-2004 07:38 AM
Redone
07-31-2003 02:04 PM
Quick Reply: Which way to rotate the distributor?
