Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty & Heavy Duty
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Super Duty & Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
  #1 (permalink)
Old 07-30-2012, 10:34 PM
featurecar50 featurecar50 is offline
Garage is empty, add now
featurecar50 is starting off with a positive reputation.
Does my torque converter have a drain plug?
I just purchased a 2001 F-350 crew cab 4x4 7.3 diesel, it was built in 2-01. I want to get the transmission serviced, does the torque converter have a drain plug? Also I have heard some 2001 transmissions have had some problems, does anyone know if mine is one of these according to the build date?
Thanks
  #2 (permalink)
Old 07-30-2012, 10:52 PM
Bullitt390's Avatar
Bullitt390 Bullitt390 is online now
Thread Hijacker
2006 Ford F-250
My Garage
Bullitt390 has a great reputation on FTE.Bullitt390 has a great reputation on FTE.Bullitt390 has a great reputation on FTE.Bullitt390 has a great reputation on FTE.Bullitt390 has a great reputation on FTE.
Nope
Josh
__________________
2006 F250 XLT 6.0 PowerStroke Diesel 4X4: Muffler/Cat/Stealth EGR delete Looney Tune BFG Rugged Terrain tires Blue Spring Mod Upgraded STC Rotella ELC DASHBOSS iPhone monitor
  #3 (permalink)
Old 07-31-2012, 08:57 AM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is offline
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
All 2001 torque converters had a drain plug when they left the factory. Ford stopped installing drain plugs early in the 2002 model year.
The problem that the 2001 transmissions had was a mechanical diode. It was installed only in the diesel trucks from the start of the 2001 model year until March, 2001. So yes, yours had the bad part when it was built.
__________________
Mark
Former Ford Automatic Transmission Engineer
“The good thing about science is that it's true whether or not you believe in it.” ― Neil deGrasse Tyson
  #4 (permalink)
Old 07-31-2012, 08:59 AM
miller_feed's Avatar
miller_feed miller_feed is offline
Hook it, I'll pull it.
miller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputation
YES, you do have the Diode in your trans. If the trans has been rebuilt before you bought the truck, that part has been replaced. From the start of the '01 build till March of '01 the Diode will be in all Diesel 4r100 trans.
As far as changing the fluid in the trans, follow these instructions from Mark K. Changing ATF Fluid in a E4OD and 4R100 transmission .: Articles
__________________
RICK, PAA MEMBER #4
2001, F-350, DRW. CC. LWB, 4X4, LARIAT,
MODS: 6637 W/Pete's cover, BTS-TRANS, DP-TUNER LIVE, MBRP 4" SS, Isspro 3 gauge kit, TN-BB turbo, Bellowed up pipes, HPX, TRU-COOL cooler, SS Stage II injectors, and the Chris-fifty.
  #5 (permalink)
Old 07-31-2012, 10:12 PM
Ok, I know the transmission has not been rebuilt, I purchased it off the original owner with 28,000 original miles. Can this diode be replaced so it does not ruin my whole transmission? I was going to install the 6.0 tranny cooler, would this help? Also was going to have the tranny flush using sythetic flud, would this help? Any other ideas or help would be appreciated.
Thanks
  #6 (permalink)
Old 08-01-2012, 08:09 AM
Quote:
Thanks
Thing is, if you take the trans apart to peplace the Diode, you just as well rebuild the whole thing. Some people go over 200k miles or more with the Diode still in there. Some people didn't get 100k before it let go. I would do the flush and keep on keeping on. I had BTS rebuild my trans with somewhere around 120k miles and they found nothing wrong with my trans and I had the Diode in it.
With my mods, I didn't want to take the chance of it leaving me on the road. If my truck was still stock, I wouldn't worry about it.
EDIT: The 6.0 cooler will help to keep the trans cooler.
__________________
RICK, PAA MEMBER #4
  #7 (permalink)
Old 08-01-2012, 09:48 AM
Ok sounds good, I will do the above mentioned things and see what happens. The truck is totally stock
Thanks
  #8 (permalink)
Old 08-01-2012, 08:59 PM
Yes it can, it involves a complete rebuild and replacing several hard parts inside the transmission that normally are not replaced during a rebuild.
It will help the trans, but it will not extend the life of the mechanical diode. When it breaks it breaks. It does not appear to be temperature dependent.
No, that won't help the mechanical diode, either. It will help the rest of the trans.
__________________
Mark
  #9 (permalink)
Old 08-02-2012, 11:40 PM
Mark, thanks for all your help, the truck has 28,000 miles, so I had to pay the big bucks. I will be towing a 22'' enclosed car hauler, when loaded it should weigh around 8,000 lbs. I will be pulling with the bumper hitch. I will be getting the transmission serviced next week. I know its hard to predict but have you seen the 2001 trannys go over 100k before they break? I hope and pray I have some more miles left in this tranny. It seems to shift fine with no issues. What kind of symptoms does the truck have when the diode fails?
Thanks
  #10 (permalink)
Old 08-03-2012, 06:36 AM
A 22 inch trailer shouldn't be any problem at all. Now if it were a 22' trailer, that would be different. (22" means 22inches, 22' means 22 feet.)
Yes, I've seen 2001 trucks go over 100,000 miles. I've seen them fail before that, too.
If the mechanical diode fails the 1-2 shift will only happen at maximum RPM, and only after you lift off the go pedal. Once metal parts that come off of it start circulating through the transmission anything else can go wrong with the transmission, too.
__________________
Mark
  #11 (permalink)
Old 08-03-2012, 10:15 PM
Ok Mark you got me on that one haha, I must have been sleep walking when I posted last night. I would like to ask you one more question, if and when this tranny fails, any recommendations of who should do the rebuild? Should I go with ford? or aftermarket?
Thanks
  #12 (permalink)
Old 08-03-2012, 11:55 PM
04Terminator 04Terminator is offline
04Terminator is starting off with a positive reputation.
I was watching horsepower tv on spike from a week or two ago and they drained the tranny then said the torque converter holds a lot of fluid wich I know. They then drilled a hole in the tc and drained it as well then put a rivet with some sealant on it . Anyone see this? Btw I know how to flush one I was just curious of people's thoughts on this.
  #13 (permalink)
Old 08-04-2012, 11:15 AM
Thanks
I can only recommend a couple shops that I know personally. Both of them are in Ocala, FL. You would need to get the truck to them. PM me if you want their contact info.
I read about several places on this and other forums that have great reputations. I'm sure they do outstanding work, but I have never used them or even met them, so I can't recommend them. Others can and will.
I also have never used a Ford reman. I have read that people are happy with them.
Quote:
Now that's some redneck engineering! What do you do next time? Drill out that rivet? Where does the part of the rivet inside the torque converter go? Does it get imbedded in the converter clutch, preventing lockup? Do you leave that rivet and drill a new hole next time? This is one of the stupidest ideas I have heard of in a long time.
__________________
Mark
  #14 (permalink)
Old 08-04-2012, 11:14 PM
Mark, I clicked on your name and my computer does not give me an option to send you a pm, I will keep trying
  #15 (permalink)
Old 08-05-2012, 01:20 AM
Crazy001's Avatar
Crazy001 Crazy001 is online now
2000 Ford Excursion
Crazy001 has a superb reputationCrazy001 has a superb reputationCrazy001 has a superb reputationCrazy001 has a superb reputationCrazy001 has a superb reputationCrazy001 has a superb reputationCrazy001 has a superb reputationCrazy001 has a superb reputationCrazy001 has a superb reputationCrazy001 has a superb reputationCrazy001 has a superb reputation
TomB985
You can keep trying for awhile, but until you make an attempt after you hit 25 posts on FTE you will not have success. PMs are disabled until then.
__________________
Tom,
2013 F150 XLT 4x4 EcoBoost
Moderators, Guidelines, and How They are Enforced
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
