FUEL PRESS SENDER UNIT?
#31
#33
UPDATE
G'day Fellas,
Got home from sea on Friday so here is an update on this tread I started.
Clay sent me a new sender unit while I was away and I put it in today.
Aaaand the result is; Bingo the ISSPRO sender unit was the culprit (defective)..
That was the second defect unit for me.
Put new one in and no more 100+ PSI .
As I had done all the fault finding steps itemised in the intial post on my thread, I still have the Silver Spring from the RiffRaff Fx, so the reading is a steady 56PSI at Idle.
I can only hope this Sender Unit lasts a lot longer than the original and the first replacement.
Cheers fellas for all the input and I hope it has helped others to fault find their fuel pressure issue .
ISSPRO need to look at the supplier??
Cheersw,
Reg
Cheersw,
Reg
#35
#36
There was another thread about this recently. I too have been thru many ISSPro fuel pressure senders. They are inaccurate and unreliable. I did buy a precise, reliable glycerin filled fuel pressure gauge from Northern Tool for $25. It is accurate and steady, but it is HUGE (4") and can only be mounted under the hood (not in cab.)
Valley Instrument Grade A 4in. Stem Mount Glycerin Filled Gauge — 0-100 PSI | Hydraulic Gauges| Northern Tool + Equipment
Still trying to come up with a reliable in cab option.
#38
#40
79Ford4x4
03-23-2010 08:59 PM
mustangman
07-08-2006 01:12 PM
