How to remove old core support mounts
my energy suspension package says if you thread the bolt into the bottom of the mount and then stick a punch through the mount and hammer it, they will separate.
I wasn't so lucky. I cut mine off. You can use a large diameter cutting wheel or a long blade on a sawzall, or even a torch if youre careful. You are supposed to reuse the top when you put new bushings in, so if you can drive them apart or even make a clean cut you will be a step ahead. If you do destroy them, they are just a piece of pipe and a washer welded together, really.
Mine were so rusted I broke a bolt inside the mount while pounding on it. Cut this off with my grinder.
I grabbed a few extra mounts at the junk yard using the same method. 2wds seem to be better donors; less corrosion from less off-roading.
Make sure you count the number of those washer things.
minnesotafisherman
08-11-2011 10:54 PM
scootin
1978 - 1996 Big Bronco
02-10-2003 10:24 PM
