F-250 front axle swap
Old 05-11-2003, 07:43 PM
Fishbowl's Avatar
Fishbowl
Fishbowl is offline
I have a 92 Ford F-250 DEISEL WITH A DANA 50 IFS. I GETTING READY TO SWAP THE FRONT AXLE FOR A DANA 60. I AM PLANNING ON GETTING THE AXLE ASSEMBLY FROM A JUNKYARD COMPLETE WITH SPINGS AND ALL THE STEERING COMPENTS FROM THE PITMAN ARM DOWN. MY QUESTION IS WHICH YEAR TRUCK WOULD BE BEST FOR THE SWAP? AND IS THERE ANYTHING ELSE I NEED TO REMOVE FROM THE DONARE VECHILE? ALSO IS THERE ANYTHING I NEED TO MODIFY BEFORE THE AXLE WILL FIT?
Old 05-12-2003, 11:40 PM
Mr Man's Avatar
Mr Man
Mr Man is offline
Use a '92 - '96 donor vehicle, and be prepared to pay a lot of money. Make sure you get the track bar and mounting bracket, and also the driveshaft (it's shorter). Everything will bolt right in.
Scott
Old 05-13-2003, 02:32 PM
Fishbowl's Avatar
Fishbowl
Fishbowl is offline
Another question do i need a six inch lift to clear the crossmember and the dana 60 housing?
Old 05-14-2003, 11:38 PM
Mr Man's Avatar
Mr Man
Mr Man is offline
I really doubt you'll need to lift it at all. I have 6" lift with a Dana 60, and my axle housing doesn't even come close to touching the crossmember when I go off-roading.
Old 05-15-2003, 07:59 AM
mooktank's Avatar
mooktank
mooktank is offline
you can use the springs you already have.
Old 05-27-2003, 11:20 PM
T/A Man's Avatar
T/A Man
T/A Man is offline
Iam currently doing this swap my self on a 97 F-250 diesel and the info I ve found is 80-97 Dana 60 years are compatable and if you use the F-350 springs you will also need the 4 inch spacer blocks for the rear axle as well as the Trackbar. We MAY also need longer shocks and brake lines. As far as cost it can be high or low depends what you find myself I found a complete junkyard Dana 60 with the proper ratio,trackbar and brakes for 400 dollars. I found that the Danas in the junk yards are more reasonably priced. Good luck.
thohill
03-23-2022 04:37 PM
Ford427Man
02-23-2014 10:28 AM
seth.chris
10-11-2013 06:52 AM
jmm
02-22-2010 08:19 AM
CowboyFromHell
23
02-25-2009 08:37 AM
Quick Reply: F-250 front axle swap
