Factory Fuel Sender Wires
Old 07-30-2012, 06:26 PM
F-250 Super Duty's Avatar
F-250 Super Duty
F-250 Super Duty is offline
Ok, I'm at the point where I'm ready to hook up the isspro sending unit into my factory fuel level gauge. I know its pin 100 but when I tried putting on wire to ground and the other to the gauge it didn't work. I have to cut both wires from the sending unit and hook them up to a relay to get this to work.
So, does anyone know, or does anyone happen to have their bed off and know what color wires are coming off the factory sending guage in the tank? I'm going to grab them somewhere along the frame rail to make my connections. If you could, look after the pigtail on the tank, I'm not sure if they are the same color on the pigtail as they are on the harness.
Stupid me forgot to look when we pulled my bed off at RRE.......
Thanks in advance!
Old 07-30-2012, 07:39 PM
CSIPSD's Avatar
CSIPSD
CSIPSD is offline
Are you hooking an Isspro Fuel Level gauge up to the factory sender? Not sure if it will read correctly...
Old 07-30-2012, 07:50 PM
F-250 Super Duty
Sure will, custom built to ford specs. Just need wire color. Tested a few months ago, now ready for install and of course I didn't take note of colors.
Old 07-30-2012, 08:34 PM
woodnthings's Avatar
woodnthings
woodnthings is offline
Mike,
Look at this Diagram Manual I have on my website, looks like page 180 & 409 show yellow/white.
Old 07-30-2012, 09:07 PM
Tugly's Avatar
Tugly
Tugly is offline
Yup, Yellow and White. There has been a rash of fuel sender issues lately and I just looked this up to answer other questions. The overhead, the PCM, and the dash connector will have it.
Old 07-30-2012, 09:16 PM
F-250 Super Duty
And I think the other wire is a red/pink. Thanks fellas!
Old 07-30-2012, 09:48 PM
CSIPSD's Avatar
CSIPSD
CSIPSD is offline
That was my next question...
Old 08-01-2012, 10:50 AM
F-250 Super Duty
So one wire from the new sender goes to the Yellow/White and the other wire on the sender will go to ground? Just want to make sure I got this right?
Z_Silas
09-15-2018 07:58 PM
scottlathrop
12-30-2012 04:21 PM
Ranger350
03-15-2011 09:40 AM
spotamiss
03-18-2009 09:24 PM
87f150xlt
03-23-2005 10:43 AM
Quick Reply: Factory Fuel Sender Wires
