4R100 PWM/NON-PWM - Ford Truck Enthusiasts Forums
4R100 PWM/NON-PWM
Old 07-30-2012, 06:49 PM
mikey89014 mikey89014 is offline
mikey89014 is starting off with a positive reputation.
4R100 PWM/NON-PWM
I have a 2001 Superduty 5.4 with an Automatic. Will a 7.3 trans with PWM lockup converter work properly , if plugged into my PCM? I'm not sure if a 2001 5.4 4r100 has PWM or NON-PWM lockup. Thanks
Old 07-30-2012, 11:09 PM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is online now
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
2001 is PWM.
Old 07-31-2012, 01:20 AM
I'm hoping the gas PCM will shift it properly . If not, will I just change the pump and solenoids to the non-pwm?
Old 07-31-2012, 01:21 AM
Thanks again
Old 07-31-2012, 10:06 AM
Change the case, too. A 7.3L case will not bolt to a 5.4L.
Old 07-31-2012, 05:15 PM
Yes, thanks. I'm thinking of installing a diesel engine with my current PCM. Will the gas PCM control the transmission , properly?
Old 07-31-2012, 09:43 PM
A gas PCM can control a diesel transmission, as long as it is also controlling a gas engine. Without an engine to control the PCM will not control the transmission.
Old 08-11-2012, 06:16 PM
Thanks for you help, i was hoping to modify the electronics to use the gas pcm with an IDI diesel engine , somehow.
Old 08-11-2012, 11:13 PM
You could get an IDI transmission controller. Or you could get a controller from PCS.
ordering a solenoid pack, does have pwm Correct? MONAVIERONJON 1999 - 2003 7.3L Power Stroke Diesel 3 07-24-2016 11:28 PM
Just checking that I'm ordering the correct part (e40dd) Az_Green_Machine 1994.5 - 1997 7.3L Power Stroke Diesel 0 11-15-2015 09:40 PM
Pump Replacement 4r100; PWM or not? ml_nelson Clutch, Transmission, Differential, Axle & Transfer Case 1 10-28-2013 09:09 AM
PWM vs. NON PWM ShoTym 1999 to 2016 Super Duty 11 08-09-2012 09:16 PM
4R100 PWM and DP-Tuner cbd1 1999 - 2003 7.3L Power Stroke Diesel 5 06-20-2010 10:39 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
