Crown Victoria suspension on Ford PU's
Old 07-30-2012, 03:44 PM
steven97439's Avatar
steven97439
steven97439 is offline
I have heard of putting the front suspension clip from a 2003 Crown Victoria under an older (1960's to 1070's) Ford F100 Pick Up. My question is will this swap also work on an 1982 Ford F150?
Old 07-30-2012, 03:52 PM
siloketh's Avatar
siloketh
siloketh is offline
What kind of goals are you trying to get with a swap like that?
Old 07-30-2012, 04:04 PM
steven97439
Crown Victoria suspension clip
It greatly lowers the front end avoiding all the steering geometry hassles.
Old 07-30-2012, 06:01 PM
TheKirbyMan's Avatar
TheKirbyMan
TheKirbyMan is offline
I don't get how welding a completely different front end from a car onto your truck is going to make anything less of a hassle...
There is a company called DJM that sells drop beams called "Dream Beams" that lower the front of our year trucks.
Old 07-30-2012, 06:30 PM
bashby's Avatar
bashby
bashby is offline
There was a thread a while back where someone did it and did a write up. The search function isn't great here but give that a try. Maybe one of the lowrider guys will remember it and help find it.
Old 07-30-2012, 06:35 PM
steven97439
Front suspension clip
As I understand it the CV front suspension is a modular one piece clip that is a direct bolt on for the older F-100s. The idea is to take the front end of the PU down to the frame, remove the crossmember and bolt the suspension clip to the now naked frame.
As I stated my question is will it work on an '82 F-150?
Old 07-30-2012, 06:39 PM
steven97439
Where would I find one of the lowriders?
Old 07-30-2012, 07:21 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
Old 07-30-2012, 08:15 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,678 Likes on 1,356 Posts
I saw a diagram where the crown vic suspension was 66 inches wide. Get your measuring tape out, how does that compare to your 82 Ford?
This would be a great swap if it would work. A clean way to get rid of the oddball twin I beam setup, and way cheaper than those beams.
Old 07-30-2012, 08:47 PM
TheKirbyMan
Well okay then. lol
flyinbrian04
02-25-2016 01:17 AM
jtpint
09-01-2014 12:59 AM
ehug21
05-18-2014 09:58 PM
Jrf100
20
01-02-2012 04:32 PM
Dyerstown
11-07-2002 04:06 PM
Quick Reply: Crown Victoria suspension on Ford PU's
