Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > International Region > Australia Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Australia Chapter Join Chapter , Leader: ChunderDownUnder
  #1 (permalink)
Old 07-30-2012, 05:58 AM
SSSimon SSSimon is offline
2005 Ford F-250
SSSimon is gaining momentum as a positive member of FTE.SSSimon is gaining momentum as a positive member of FTE.
Harpoon/hutch/FRX/Fuel bowl delete in one kit
When I did the fuel bowl reseal, I took the opportunity to watch the fuel bowl fill up with fuel. I noticed a fair bit of foamy fuel coming into the bowl and so figured that when the Longranger-extended fuel tank was put into my truck by the PO he did NOT take the opportunity to do the harpoon & hutch mods.
So now I've got to drop the biggest F250 fuel tank on the planet, 270 litres, to do the job 'properly'.
Diesel Site has this kit:
http://www.dieselsite.com/dieselsite...9-200373l.aspx
Plus - it's one kit, I've ordered from this site before without a hassle;
Minus - It doesn't contain the AirDog one pump/filter set up.
Clay doesn't seem to have a complete kit, including tank pick-ups and fuel bowl delete connectors, like this one.
Any thoughts on this?
__________________
Mods done: lots of cheap mods (Hutch, IC boots, plenum inserts, IH uppies, HPx, AIH delete, EBPV delete, hi flow outlet, CCV mod, OCR, Superchips, Zoodad, 6637, 4" TB exhaust, JW valvebody, coolant filter, FRx, '05 HD lights with switch bypass relays, B100 ready fuel system)
Mods NOT done: big oil, big brakes, big turbo
Next mods: ? tuner, G2WW (on the shelf), alloy diff covers
Australia: where Mechanics use spanners and Plumbers use wrenches...
  #2 (permalink)
Old 08-01-2012, 12:26 AM
ChunderDownUnder's Avatar
ChunderDownUnder ChunderDownUnder is offline
Garage is empty, add now
ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.
why do you want an Airdog ???
just got this kit
Driven Diesel 7.3L Bowl Delete Regulated Return Kit
with post pump filter (2 micron). already have the prepump filter set up. Gunna run with my carter fuel pump and might try for a pre pump lifter.
You can source a prepump locally. with some fittings and hose you are good to go
http://www.westernfilters.net.au/pro...roducts_id=706
around 1100 AUD and you have the lot
__________________
Brian
03 F250 XLT LB . Full Engine build with all the goodies. Tuned by Matt
- cant wait until my motor blows so I can blame someone else -
join the Australian Chapter here-Join Chapter
  #3 (permalink)
Old 08-01-2012, 05:13 AM
2005 Ford F-250
I was looking at the Air-dog one to provide out of tank filtration and fuel push to the stock fuel pump. This avoids overloading the stock pump by making it suck fuel through from the tank and through a remote filter/water separator.
The Diesel-Site kit included the in-tank mods, but doesn't include a pre-filter pump.
On Driven-Diesel, they recommend a 2 micron filter after the stock pump for fuel bowl delete. That filter would catch any debris from a decaying stock pump I guess.
I would like to do the mod, but would also like to be confident that I have all the bits and pieces I need before I start the project.
I've emailed Clay to see if he is interested in putting something together for me as he is a supplier of the Air-Dog 1 pump-filter combo.
So Brian, are you just using the stock fuel pump and running the pre-pump filter-water seperator and inserting an inline 2 micro filter to replace the fuel bowl filter - so a one pump fuel system?
__________________
  #4 (permalink)
Old 08-01-2012, 05:32 PM
Im planning on a lift pump then the carter and carrying a spare. Only because I want to get this thing running by Sept. I may go to a dual pump set up later on. I dont think the Airdog is worth the money
__________________
Brian
  #5 (permalink)
Old 08-01-2012, 10:12 PM
Ratkat's Avatar
Ratkat Ratkat is offline
Ratkat is gaining momentum as a positive member of FTE.
In my opinion the Air dog was worth every cent improved economy and performace in my truck. The performance change was like comparing it to running on a hot day to running on a cold day it is noticable. Can not remember what the economy was but I was impressed. I would not hesitate to fit one in the future to another truck.
__________________
Geoff
2002 F250XLT Superduty AFe 11, CCV, HPx, FRx, Air Dog, Ceramic Coated Manifolds and bellowed up pipes, 3.5" to 4 " Magnaflow, 38r high flow outlet ceramic coated, Stage 11 injector's, 20 cent mod (only for Australians) JW Trans DB sump, Di Pricols, 2x pyro, boost trans, Dp, modified stock, 40tow, 60tow, High idle, 60 econo, 80econo, 120race, drive thru, Low fuel so far.
  #6 (permalink)
Old 08-02-2012, 05:03 AM
Tugly's Avatar
Tugly Tugly is online now
I'm a cautionary tale
2000 Ford F-250
Tugly has a brilliant futureTugly has a brilliant futureTugly has a brilliant futureTugly has a brilliant futureTugly has a brilliant futureTugly has a brilliant futureTugly has a brilliant futureTugly has a brilliant futureTugly has a brilliant futureTugly has a brilliant futureTugly has a brilliant future
I don't have experience with an Air Dog, but I "read the brochure". Their video is misleading; the fuel doesn't flow that fast, so the tank would not be that aerated and agitated. The video exaggerates the problem, and misleads in another way: After the Hutch mod, my problem was the tired quick-disconnect to the tank introducing air. Just replacing the fuel lines got rid of the last of my air.
  #7 (permalink)
Old 08-02-2012, 05:33 AM
2005 Ford F-250
Hi Tugs, thanks for that. When I did my fuel bowl reseal I left the top off the bowl and watched the fuel coming in. It was very foamy. But I haven't done the in tank mods, i.e. hutch and harpoon. When I drop the tank I want to remove the stock strainers and go to an external water seperater & course filter set up, something like the Air-dog 1, and carry spare filters. The nice thing about the Air Dog is you get the pump and filters in one neat unit.
The aim would be then to insert a 2 micron filter in front of the stock fuel pump, put on a fuel bowl delete kit, and thus make the fuel system bio-diesel compatible. All diesel over here is already ULSD, which was what disolved the stock seals in the fuel bowl - mainly the 4 yellow ones 'sealing' the fuel bowl drain valve.
I haven't had any replies from my email enquiries to Clay at Riffraff or Diesel site yet. So far the best option I can come up with is the Driven Diesel system (Brian's link above) with the 'extras' + getting an Air Dog 1 - about $1400 worth + shipping (glad it's not as bulky as leaf springs or an exhaust system which were my previous orders).
__________________
  #8 (permalink)
Old 08-02-2012, 06:15 PM
Quote:
Hey Geoff. Do you have a way of checking Fuel psi at WOT runs. Thats where the problem has been noted with the Airdog. They just cant keep up.
__________________
Brian
  #9 (permalink)
Old 08-03-2012, 06:27 AM
2005 Ford F-250
AirDog 1 is for stock to mild. AirDog 2 is their 'race spec' offering, pumps 50% more fuel than the 1, but causes problems in a stock truck as the stock fuel return line cannot cope with the volume of fuel NOT being used by the engine - resulting in a pressure build up.
Brian, with your truck you'd probably have to go for the Air Dog 2 and upgrade your fuel return line for when you're NOT pushing the pedal to the floor! When you did push it, the extra volume from 2 would cope with your engine's fuel demands.
One other question, that fuel bowl delete kit you posted, does that have a 1/4 inch NPT port for a fuel gauge?
__________________
  #10 (permalink)
Old 08-03-2012, 08:06 AM
1/8 NPT Simon
__________________
Brian
  #11 (permalink)
Old 08-03-2012, 10:41 AM
tiny1's Avatar
tiny1 tiny1 is offline
NY CHAPTER LDR
2001 Ford F-150
My Garage
tiny1 has a superb reputationtiny1 has a superb reputationtiny1 has a superb reputationtiny1 has a superb reputationtiny1 has a superb reputationtiny1 has a superb reputationtiny1 has a superb reputationtiny1 has a superb reputationtiny1 has a superb reputationtiny1 has a superb reputationtiny1 has a superb reputation
Simon, I believe that Clay is at the All Truck Nationals this weekend which is a very large show of everything dealing with what else.... trucks! That maybe the reason why he has not responded to your inquiry.
__________________
Neil aka Tiny aka Hugo...... Official #2 Slackmaster & Pyroslacker Extraordinaire
2001 F150 XLT Supercab 4x4 & 2008 Edge SEL AWD
To Join The NEW YORK CHAPTER CLICK HERE
RIP Phil, phil6608.... you will be sadly missed my friend
  #12 (permalink)
Old 08-04-2012, 04:45 AM
2005 Ford F-250
Clay's replied. Basically for a stock situation Clay recommends the in tank mods (hutch/harpoon) and the FRx - regulated fuel return. Nothing else really necessary.
I'm still not sure though if the stock fuel system, including fuel bowl, will cope with B50 or B100 bio-diesel - this is why I was looking to upgrade the fuel system.
__________________
  #13 (permalink)
Old 08-09-2012, 06:38 AM
2005 Ford F-250
Clay advises that the stock fuel bowl will handle bio-diesel - which is in pretty common usage in his region.
For the moment I'm going with the tank mods, taking out the in-tank filter-strainer, and mounting the external Western Filters filter/water seperator unit (that Brian recommended above), then use a FRx as the simple air/foam bleeder to handle any non-solid fuel getting through the stock fuel bowl.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
