Door lock cylinder, all the same?
Old 07-30-2012, 12:03 AM
Vanaddiction's Avatar
Vanaddiction
Vanaddiction is offline
I got my '95 Club Wagon up for sale, and I probably will have to replace all the lock cylinders since they're all froze. Only way in is the fob. I've seen a set of 4 on-line, for '97-'07 vans, for under $50 and that sounds good, other sets don't specify a year.
So, are there different styles over the years? Or would '95 be the same as '97? Obviously I have power locks, so does that affect the cyl?
Do they ever free up the with penetrating oil? I've been trying on and off for months with no luck.
thanks.
Old 07-30-2012, 12:26 AM
joshofalltrades's Avatar
joshofalltrades
joshofalltrades is offline
i know for a fact that on the older body style (thru 91), all door locks are interchangeable between positions, and also between other fords of the same key style. this also gives us the freedom to step away from the 2-key system and install door locks from an older ford on the same key as the ignition.
i haven't studied them on the newer body style vans, but i suspect you'll find them similarly interchangeable
Old 07-30-2012, 07:54 AM
blageurt's Avatar
blageurt
blageurt is offline
The current lock on the rear barn door on my E350 truck is from an Aerostar mini van
Old 08-02-2012, 11:23 PM
Vanaddiction
We are scrapping a '98 E-250 cargo at work, all the door locks work and the ign is not loose. Boss says take what I need. Assuming they will work on my '95 w/power-locks even though the cargo has no power-lock.
Old 08-02-2012, 11:33 PM
joshofalltrades
usually the cylinders are the same regardless of power locks, the power unit is on a linkage just like the inside lock handle. may as well take the whole set
Old 08-03-2012, 10:51 PM
Vanaddiction
Thanks Josh, that's the plan, including Ign, keep it all one key.
Old 08-06-2012, 10:06 PM
Vanaddiction
Close but not quite...
I installed all the lock cylinders from a '99 E250 into my '95 club wagon, doors and ign.
Ign was a direct fit, my old '95 ign cyl is now in the '99 and vice versa.
Doors were a bit different, while they look the same, shape etc., the '99 cylinders are just a bit larger than the '95. So I had to enlarge all the lock holes in the '95 doors to use them. Same shape hole, just about 1/10th inch bigger. A job that probably could have been done in an hour or so, with panel removal, took me 2 1/2 hours to complete, using die grinder and files.
The clips that retain the cylinders are also a bit larger, to fit the bigger cylinders.
I'm glad I got these locks and keys for free, really can't complain!
dukefan70
09-03-2023 09:57 AM
comet
38
12-10-2018 03:39 PM
Texmudder
2017+ Super Duty
11-13-2017 10:59 AM
akuhr93'f150
23
01-10-2013 08:04 AM
MDK
1997 - 2003 F150
09-05-2003 08:29 PM
Quick Reply: Door lock cylinder, all the same?
