Windshield wiper arm removal? - Ford Truck Enthusiasts Forums
Old 07-29-2012, 09:09 PM
FlaresideF150's Avatar
FlaresideF150 FlaresideF150 is offline
FlaresideF150 is starting off with a positive reputation.
I wanted to take my windshield wiper arms off to paint them. Ive covered everything in newspaper before and sanded them and painted them but that didnt last long so i want to take them off and sand blast them and put a few good coats of paint on. Does anyone know how to get them off without any special tools?
Old 07-29-2012, 09:20 PM
rla2005's Avatar
rla2005 rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
From my Ford Service Manual:
Removal and Installation
1. Raise windshield wiper blade (17528) end off windshield and slide latch away from windshield wiper mounting arm and pivot shaft.
2. Unlock windshield wiper pivot arm from windshield wiper mounting arm and pivot shaft.
3. Remove windshield wiper pivot arm. Windshield wiper pivot arms can be removed and installed without the aid of any tools.
For installation, follow removal procedures in reverse order. If windshield wiper blade does not touch windshield, then slide latch is not completely in place.
The latch they are referring to is on the wiper arm itself. Once you lift the pivot arm you will see what they are talking about.
Old 07-29-2012, 09:24 PM
materthegreater's Avatar
materthegreater materthegreater is offline
materthegreater is gaining momentum as a positive member of FTE.
One of my wiper arms keeps falling off by itself!
Luckily it's the passenger side...
Old 07-29-2012, 09:31 PM
Are you referring to the little latch that slides uo underneath the arm that will hold it off the windshield?
Old 07-29-2012, 09:49 PM
rla2005's Avatar
Take a close look at the wiper arm itself. Where it attaches to the drive mechanism is a small latch. Lift up on the arm, then pull on the latch, let loose of the arm, it will rest against that small latch arm once it is pulled out. Once that is complete, pull up on the entire assembly, it will come off the pivot point.
Old 07-30-2012, 09:18 PM
Thanks that should do it. Ive always used that latch to hold the wipers off the glass when im washing my truck or cleaning the windows i never knew it was for removing it.
wipers Hibiscusmile 1997-2006 Expedition & Navigator 7 01-30-2014 09:11 AM
Wiper Arm Removal?? berry1234 2007 - 2014 Expedition & Navigator 3 11-14-2013 10:53 AM
Windshield wiper removal AustinF250 1987 - 1996 F150 & Larger F-Series Trucks 8 08-07-2013 08:10 PM
How to remove rubber wiper blade arm assembly? razor_jim Aerostar 5 01-11-2004 01:23 PM
Painted Mirrors Aftrmidnite Aerostar 2 12-14-2003 04:48 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
