Dual Mass Flywheel - Ford Truck Enthusiasts Forums
Dual Mass Flywheel
Old 07-29-2012, 08:28 PM
89 F-250 man 89 F-250 man is offline
89 F-250 man is starting off with a positive reputation.
Dual Mass Flywheel
I have had trouble getting my truck into reverse since Ive had it. Here recently its getting harder to get into first it has a new clutch and slave cylinder. The clutch engages about an inch off the floor I've been doing some research and read that the dual mass flywheel could cause this. The fly wheel shows all the signs of being worn out such as chattering loose springs and a loud clunk when you turn the truck off if you have any opinions about this or if the flywheel could cause the reverse problem please respond. Thanks
Old 07-29-2012, 08:46 PM
xcite xcite is offline
xcite is starting off with a positive reputation.
Check the plastic bushings under the dash on the petal linkage, then ensure all air is out of hyd for clutch pedal.
Old 07-29-2012, 09:03 PM
should i still replace the flywheel if the springs are loose and rattle at idle
Old 07-29-2012, 09:05 PM
If it where me I would still replace it, but the main root cause maybe something else. You just want to eliminate all possibilites while you are at it.
Old 07-29-2012, 09:33 PM
I went and checked the clip and it was missing so for the time being i wrap the piece coming from the clutch pedel with tape so that the rod was tight it now goes into gear with ease a 12 dollar part is much less than a flywheel now to replace the rear seal what a job to come
Is there a way to tell DMF or SMF without removing trans? MackGuy 1994.5 - 1997 7.3L Power Stroke Diesel 6 07-24-2014 12:24 PM
clutch problem 89 F-250 man Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 07-30-2012 06:49 AM
Dual Mass Flywheel MustangMatt96GT 1994.5 - 1997 7.3L Power Stroke Diesel 4 02-28-2009 07:30 PM
dual mass flywheel/clutch ?s arkredneck 1994.5 - 1997 7.3L Power Stroke Diesel 21 01-18-2009 09:46 AM
Dual Mass Vibration ? otto 1999 - 2003 7.3L Power Stroke Diesel 7 09-17-2001 07:54 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
