Will an alternator from an '05' work in a '97'? - Ford Truck Enthusiasts Forums
Old 07-28-2012, 11:38 PM
berick's Avatar
berick berick is offline
berick is gaining momentum as a positive member of FTE.
Trying to sell my old alternator and I have a guy with a 97 7.3 Powerstroke that thinks it will work in his truck. Mine is an '05'.
Old 07-29-2012, 03:34 AM
Yahiko's Avatar
Yahiko Yahiko is online now
Yahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputation
First question would be "Will it fit?"
The next would be "Is the control system compatible?"
I recall that ours in internal regulated but still have 3 wires
It really depends on how the PCM in both trucks control
the alternator.
I did look up the 06 and found one wire goes to the battery
a second wire also goes to the battery and the third to the
instrument cluster. Now doing back to charging systems from
school the 1st wire to the battery is the B+(charge power)
the next one to the battery is to operate the regulator and supply
the power for the field coil. The last one is the ground/control
wire for the PCM and indicator.
Short answer is it should work with some modifications to his truck
if Ford did not change too much maybe very little or none. I would have to know
how his charging system works. Maybe one of the Ford techs can give some
input on this.
Sean
Old 07-29-2012, 10:22 AM
berick's Avatar
No worries...... found something online and it looks like 99-07 are compatible.... his is a "97" and therefore has the large body style alternator and an extra plug on the back for something.
washed engine at car wash, now no alternator charge... PPrash 1999 to 2016 Super Duty 12 05-06-2011 03:06 AM
Is it possible to put dual alternators on a 5.4? bcg Modular V8 (4.6L, 5.4L) 5 03-01-2009 02:30 PM
Downsizing to an F150 pros and cons? Skipstowin 1999 - 2003 7.3L Power Stroke Diesel 24 01-11-2009 05:33 PM
HD Alternator Downriver Thunder 1999 to 2016 Super Duty 1 01-02-2009 07:56 AM
97 F150 4.6L alternator fuse bub3788 1997 - 2003 F150 2 02-13-2003 01:08 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
