Anybody replaced the plasitic CAC tube?
I got my Riffraff boots and metal CAC tube yesterday and I'm a little confused.
Riffraff Diesel: Driver Side Metal Intercooler CAC Tube Kit
The tube in the picture in the link above is up side down so hard to say which boot goes where. The online instructions are (I'm guessing) for a 7.3 as none of the pics or text matches what I'm looking at. Does the shorter boot with the ring around it go on the bottom of the tube or the top? I've put it together both ways and it doesn't seem to fit up like I would like it to.
No trimming needed. The pipe is the stock one from Ford, the hump hose goes up top like shown by Steve and the long straight on the bottom. The picture is incorrect on our site, I am sorry.
Sorry for the . But I'm just curious.
I have a 2004 with the plastic CAC tube. I've had it off half dozen times or more, to work on this or that. It seems solid, it's held up for 75k miles, hasn't split, broke and doesn't leak. And it's on the cold side, so it doesn't that hot.
Yet there seems to be a move for people to replace them. Riff Raff sells the entire kit. Have people been having problems with the plastic tube that I haven't read about? If it did break, split or leak, why would I prefer the metal tube over the plastic one? The plastic one seems solid enough and I imagine it is a fair bit cheaper, being just one piece with two clamps, vs 2 boots, the metal tube and 4 clamps.
Just curious.
Just curious.
Thanks Clay. I guess part of what was throwing me off is the ring on the shorter boot looks like it was made to allow a little wiggle. On the factory plastic piece the corrugated part is on the bottom near the intercooler. I'll try it again.
Well, finially got it in where I was happy with it. Apparently, when doing some recent work I must have "tweaked" the dipstick tube and mount a little bit. It was pushing the metal CAC tube forward in the middle and it would teeter-totter and push the boots out of shape. Thanks for the help.
David,
In my case the plastic boot had a couple of cracks in the corrugated part. I'm at 140k+ miles. No telling when it started leaking, I guess it snuck up on me (plastic is like that ).
Metal pipe with boots will pop someday.
David,
Good luck
Now, go enjoy the day!!!
As for the rest of us, back to our regularly scheduled maintenance day! ( j/k )
Happy Independence Day everyone!
Just curious.
Just curious.
Dave its the Repeated Hot/Cold cycles in the engine bay that makes the tube Brittle and Crack
Heat and plastic dont go well together over time
You could always do the Duct Tape MOD LOL
I can also see where someone working on the truck may have caused the crack too but IDK what happened with the 1 thread there was a cracked tube if it was self inflicted or Not
The Plastics are getting better more Durable these days
not like some the plastic on the older cars that cracks if you even touch it
