Newbee here with trouble codes p0022 - Ford Truck Enthusiasts Forums
Old 07-29-2012, 12:21 AM
nlaao03 nlaao03 is offline
nlaao03 is starting off with a positive reputation.
First off I really enjoy this site. I have been reading it for the last few days now and have found a lot awesome information.
Now for my problems I am having. I recently bought a 2005 2wd F150 5.4L with 135xxx miles on it. I bought it knowing it had a code of P0345. The PO stated that it would shutter every once in a while when he was putting around in parking lots and if he gave it gas it would quit. I also have reciepts of work that has been done in the last few months. He replaced timing chains, guides, ect... with the exception of the cam phasers. Had the drivers side VCT solenoid and cam sensor replaced, changed all spark plugs, and also changed the lifters on the drivers side. He also stated he had a mechanic hook up a oil pressure guage and it all tested good. Can not confirm that though.
Now since I have had the truck for about a week I know what the truck is doing. After it warms up when I stop or going through drive thru it will shutter like crazy and give that diesel sound. It has even died on me a few times in my yard just putting around.
The things I have done so far: I swapped sides of cam sensors, reset computer and code p0345 cam back. I then checked the VCT solinoids and confirmed one was new and the other didn't look dirty or bad so I swapped them from side to side to see if anything would change. I then got a code of just P0022. I decides to change the oil and filter just to be sure it had the right oil in it. It had a motorcraft oil filter on it so that makes me feel a little better. I replaced it with another motorcraft one. I had autozone reset the computer again and it is still showing P0022 with P0345 pending. I am going to replace the cam phasers, is there another thing I can check.
Problem with P0345, P0022 thegalindo1985 2004 - 2008 F150 13 05-17-2014 02:28 PM
Code Help: P0022 and P0345 Johnis 1999 to 2016 Super Duty 3 10-28-2012 01:30 AM
Need Help. P0012, Im stumped nlaao03 Modular V8 (4.6L, 5.4L) 5 09-21-2012 10:02 PM
At wits End... P0345 - low oil pressure 06 F150 5.4 Steve_Uzi 2004 - 2008 F150 4 07-25-2012 11:14 PM
2007 F-150 codes- p0012, p0022, p0345 tley0218 2004 - 2008 F150 3 05-30-2011 06:32 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
