Transmission guru's... please advise!
So the automatic transmission on my 2006 6.0l diesel has been acting up. its got 2 stuck solenoids, i drain the Transmission fluid (oil?) and removed the pan. what i found is what i think is clutch material residue on the pan... there doesn't seem to be any "big" pieces of clutch, just a lot of very fine shavings if you will.
i have attached some pics to help you guys understand what i am looking at. Im not sure if this is "normal" or if this is a sign that the clutches inside the transmission are gone.
Background on the transmission...
i bought the truck with 42k miles on it 3 years ago. i was told by the dealer that i bought it from that they had serviced the transmission when they took it in as a trade in. i have since put about 44k miles on it and i have not serviced it since i bought it (not good i know).
assuming that the dealer really did service it this build up would have happened in the last 44k miles since i bought it. if they didnt service it then this is 86k miles worth of build up.
I guess not what i need advice on is whether i go ahead and try to flush the transmission and clean it all out ( lines, cooler, solenoids, pan etc.) or if its beyond repair and just needs to be overhauled.
Thanks for any input.
gooldg
06-26-2019 06:32 AM
dturnersr
12-25-2018 03:01 AM
chetspencer
10-02-2017 11:37 AM
