Looking for input on a 51 F1 Build
Hello, I have just joined this forum, but have been a Ford guy since I could drive (Own 3 Late model Mustangs currently). Anyway, I have just purchased a 1951 Ford F1 from a friend to add to my collection. I have been cruising many F1 sites to learn as much as I can about these cool vehicles and wanted to get some opinions on my initial build plan.
The truck already has a drive train from a '79 Lincoln Versailles already...a 135HP 351W and C4 Auto....Huge power!!!
Anyway, my plans:
Frame-off and box the frame
Mustang II IFS - Disk Brakes
8.8 rear with a 4-link
18" wheels (possibly late model Mustang)
408 Stroker (based on 351W)- possible Fuel Injected with Mustang Fuel tank and pump, Accel DFS
5 speed transmission (still need to decide on this)
As you can see, I am a mechanical guy...I will do all the body work, but nothing special
Any thoughts? Is this a poor start? Should I consider other options?
Does anyone know what manual transmission would be the best for this truck and a 351W? I am familiar with my t-5's and Tremec TKO, but not sure that either is the proper tranny.
Thanks in advance, I realize this is all personal taste....but I like to get opinions of those of you who have been there and done that.
Anyway, my plans:
That's quite a heavy list of mods with some conflicting with others. Typical of newbes wanting to throw everything at a build. I always recommend sitting down with pen and paper an without any preconceived list of mods for the sake of mods or because of what the magazines show or people tell you is "cool" or must haves.
Instead make a list of all the things you want your truck to be "when it grows up". use functions rather than mods: Daily driver; trailered drag racer; serious competitive show truck; "lawn ornament" (local fun only shows); work truck (type of work, and loads carried and/or towed); long distance cruiser with all the modern comforts; etc.. You may see it as having multiple functions, then you should give them an order by importance. Next make a list of what would make the truck suitable for your purpose. Finally make a budget of time and money that you want to invest. One truism: whatever your most generous and/or optimistic budget, it will actually take 3 times as long and cost 4 times as much as you budgeted.
on
Welcome to FTE! Ambitious plan...but I like it except for 18 inch wheels! IMHO, these old trucks look better with stock or near stock looking wheels and tires. As others have said, figure out what you want the truck to do and what you want to use it for and that will help sort out your plans.
Thanks guys...Awesome community
Thanks everyone...I can tell that this build will be a fun one. This is a great community already. OK...so that is what I am trying to do here..measure up what a good plan is. So I will tell you a little about my other vehicles and what I want to do here...
I want a driver that is comfortable and will turn heads (and has 400-500HP). I know I need to change the suspension and brakes for this. I am comfortable with the small block, but only have experience with the 5.0 liter (and stroker versions). I have considered building a big block, but that gets into big bucks and outside my knowledge (but I could figure it out).
I guess I just wanted to test the waters to make sure that someone wouldn't say....why are you using a small block, the big block is the way to go, or why an 8.8 rear...the XXXX is a direct bolt in, better and easier.
Again, thanks guys. This is an awesome board!
Now, where are your pics???
Looks like a 52 to me. What is the fourth character in the serial number (VIN)? Is it a 1 or a 2? 1 is a 51, 2 is a 52.
The hood, hood moldings and the hood latch panel (with the FORD letters) is what makes it a 52. Also, is there a serial tag (VIN tag) affixed in the upper right hand corner of the cowl inside the engine compartment? 52s didn't have this tag, while 51s did.
