Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 07-28-2012, 08:08 PM
99hosss 99hosss is offline
1966 Ford F-250
99hosss is starting off with a positive reputation.
starter solenoid
Hello forum, in order to start my truck, I had to run one side of the solenoid to ground. Where does that clip on wire normally go? I ohmed it out and it went to the "acc." side of the ign switch. I had to remove it and ground one side- whats going on w/ that?
__________________
My addiction- wire brushing rust
  #2 (permalink)
Old 07-31-2012, 05:08 PM
mcdonaldm mcdonaldm is offline
Garage is empty, add now
mcdonaldm is gaining momentum as a positive member of FTE.
i am not fully understanding what you are saying. you had to ground the solenoid. what post did you have to ground? you shouldn't have to run a ground from any of the posts on the solenoid.
the Ford solenoid is a pretty simple device. the two large copper posts go to the battery (+ side) and the other one goes to the starter. there will be a couple of other wires attached to the positive side, these are for main power and battery charging.
depending on the solenoid you will have either one or two small terminals marked S and I (if a two post version).
the S terminal goes to the start position on the ignition switch and sees 12v during starting while the I terminal goes to the + side of the coil to give it a full 12v when starting, then when started the coil gets power thru the on position of the ignition switch at a reduced voltage. not all vehicles are wired this way so the I is not always used.
the body of the solenoid is the ground path so you have to make sure that there is a good ground between the metal mounting tab and the frame or whatever you have it mounted too.
if youhave to ground one of the terminals, something is wrong with your wiring.
rgds
Mike
  #3 (permalink)
Old 07-31-2012, 05:20 PM
arctic y block's Avatar
arctic y block arctic y block is offline
Old School
1962 Ford F-100
arctic y block has a spectacular reputation.arctic y block has a spectacular reputation.arctic y block has a spectacular reputation.arctic y block has a spectacular reputation.arctic y block has a spectacular reputation.arctic y block has a spectacular reputation.arctic y block has a spectacular reputation.arctic y block has a spectacular reputation.arctic y block has a spectacular reputation.arctic y block has a spectacular reputation.arctic y block has a spectacular reputation.
Quote:
rgds
Mike
Or it may not me a Ford starter solenoid. Does it have one or two small posts? The ones made for like a winch motor I have seen have to be grounded with one of the post to make them work. Or maybe I had them wired wrong also.
__________________
85 XLT Bronco 351W HO 4V Dual Pipes 33X12.5 BFG's
62 Uni 390 C6 Custom Cab Not Yet Sold
Looking to buy a 48/50 F Anything If ya have one contact me.
Don't just Modify it Fordify it
  #4 (permalink)
Old 07-31-2012, 08:53 PM
1966 Ford F-250
yeah, its a ford solenoid, the s terminal is ok, the i term. is where I ran to ground. Starts like it should, no battery drain- I must have an open wire on the I term. Anybody have the 60 wiring shot of that circuit?
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
