Removing the tray/bed for fuel/gas tank work - Ford Truck Enthusiasts Forums
Old 07-28-2012, 07:57 PM
Shrek_Australia's Avatar
Shrek_Australia Shrek_Australia is offline
Shrek_Australia is starting off with a positive reputation.
Hi All
Currently working on problem with my fuel tank fill hose and it appear for ease of replacement it would good to take the bed/tray off to do the work. I also have chassis bushes to do so can do two items at once.
I have never taken the bed off before so thinking this looks simple? Disconnect brakes lights, indicators etc, then remove bolts for bed? Anything I am missing?
Cheers
Old 07-28-2012, 08:20 PM
Canus Canus is online now
Canus is starting off with a positive reputation.
Don't forget to remove the 4 screws attaching the fuel fill tube to the bed.
Old 07-28-2012, 08:55 PM
Blue and White Blue and White is offline
Blue and White is gaining momentum as a positive member of FTE.
Yep, pretty straight forward. I use an engine hoist and a length of timber placed under the inside lip of the bed to lift.
Old 07-31-2012, 06:38 AM
So it is just the screws to the chassis from the bed and the fuel filler tubes and then rear lights?
Old 07-31-2012, 07:14 AM
earthquake68's Avatar
earthquake68 earthquake68 is offline
earthquake68 has a very good reputation on FTE.earthquake68 has a very good reputation on FTE.earthquake68 has a very good reputation on FTE.
Yup, that's it. Something to keep in mind, though. The gas tank ONLY will come out from the bottom. Taking the bed off doesn't make it any easier. Another thing. There are NO body bushings under the bed. It bolts directly to the frame, so there's no need to remove it for that reason either. Spring bushings aren't that hard to replace with the bed on either. You have to remove the spring anyway to get the bushings, so you just work on the spring away from the truck.
BUT, ...if you have your heart set on removing the bed, by all means, go for it. It's a great time to get some cleaning and painting done on the chassis.
Fuel Tank - Bed Removal Joel Cassell 1973 - 1979 F-100 & Larger F-Series Trucks 6 11-12-2014 05:11 PM
I have 8"! What do I do with it? LeoJr 1994.5 - 1997 7.3L Power Stroke Diesel 7 08-12-2014 05:11 PM
bed bolts help needed yargnitram 1961 - 1966 F-100 & Larger F-Series Trucks 8 06-07-2014 06:17 PM
Battery hold down tray on driver's side. 2011 PhotoDon 6.7L Power Stroke Diesel 6 05-07-2014 08:48 AM
Which is easier: remove bed or drop fuel tanks? Brad Leroy Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 16 11-07-2013 06:04 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
