Air intake & Exhaust mod
Both gassers have nearly identical intakes and those intakes are already cold air intakes. If there is a small "issue" with them it may be the nearly 90* bend the intake tube takes.
Opening either end will give a few more ponies up top and a bit more noise. Don't expect those mods to improve MPG to any degree.
I pull a steady 14 on the highway at just below 65, and that's turning 37's and 4" of lift. I've got the K&N CAI, Jet Throttle Body Spacer, Superchips Tuner, and nothing behind the cat.
Every vehicle I have ever owned its made a difference on, but least most of all on the ex., I'm assuming it's because of the size.
