Oxford white code YZ Touch-up what type of paint did ford use? - Ford Truck Enthusiasts Forums
Old 07-28-2012, 02:20 PM
F2502011 F2502011 is offline
F2502011 is starting off with a positive reputation.
Wanting to do some touch-up work. A spot repair. The vehicle is a 1996 Ford Truck Oxford White paint code YZ. I know it's a base clear finish but I haven't been able to find out what type (urethane, lacquer, enamel etc.) that ford used at the factory or what would be the best type to buy to do this. I plan to fill in a small ding, prime, paint the spot, then clear the entire panel. Anyone with any info or tips on this please let me know. Have been debating on buying the premixed duplicolor championship white but not sure how close of a match that would be so I plan to go to the auto paint store but I need to know what would be the best type of paint to get to do this and whatever else I may need (reducer, hardner, etc) to most closely duplicate the factory finish. Thanks
Old 07-28-2012, 10:11 PM
Beechkid Beechkid is offline
Beechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud of
Quote:
oem paint is laytex
avoid duplicolor unless you are repairing paint chips/nicks
an auto paint supplier can color match (with a laser or if they are ol timers, by eye) the paint. They can also pre-mix the paint for your gun so minus the hardner, its ready to go- a $ saver. Lacquer is the easiest to use on a small repair but its almost impossible to find....next choice would be Urethane- works & finishes much like lacquer.
White Platinum Metallic Tri-Coat question Criegg 1999 to 2016 Super Duty 1 07-13-2016 09:06 PM
Help - Paint Experts, coding for Oxford White cartmanea 1999 to 2016 Super Duty 22 10-27-2010 10:57 AM
Help - Paint Experts, coding for Oxford White cartmanea Paint & Bodywork 1 10-26-2010 10:03 PM
Where to buy touch up paint online? itsaford 1999 to 2016 Super Duty 8 09-05-2010 04:13 PM
painting my truck? F-350 Mud Digger Paint & Bodywork 8 06-02-2010 07:03 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
