Carburetor suggestions
Stop being a backwards luddite and keep the EFI system. The speed density system is pretty bomb proof and Ford spent millions figuring out how to optimize fuel delivery and ignition for that combustion chamber style. If you swap to carb you'll wind up being less aggressive on timing and less precise on mixture and you're gonna lose a few ft*lb of torque across the board swapping to a carb.
If you're going to throw a big cam at it then sure, swap to a carb, pretty much any four barrel will be too much unless you do head work to take advantage of the cam.
I'm sorry, maybe I should have said that I AM going to put a carburetor on my truck. If you don't have a suggestion for a carb don't bother leaving useless comments. I grew up with carbs and will die with carbs. Just looking for some feedback, I already know what I need, just putting my feelers out.
Thanks
Thanks
Not to be rude, but you're not going to get a lot of help here. Not many people in this section bother building 4.9/300s, and even fewer go backwards by getting rid of the EFI system, losing power and making their truck worthless by turning the engine bay into a cobbled mess.
You will get much better help at the FordSix or Inliners forum, since they almost exclusively deal with the older carb'd iterations of these engines.
There is an inline six forum further down the main here too: Ford Inline Six, 200, 250, 4.9L / 300 - Ford Truck Enthusiasts Forums
But for the cost of the carb, manifold and everything else, he could have converted to the Mustang mass-air system.
I totally understand. I miss the simplicity of carburetors, condensers and points, yada yada. I'm 69 years old and old fashioned like most folks my age. However, I have found that working with these new "confound" engines is a challenge and educational experience, plus the simple fact that they are WAY more reliable. Come into the 21st century...I did, kicking and screaming but I did. BTW, I kinda' like an engine that will tell me what is ailing it. Amazing thing!
I'm on the fence. For something I drive every day and have to get to work and back in I have kind of gotten use to the having a car that starts on cold mornings, warms up fast, heats up the seats for me, A/C always works and that I dont smell like exhaust when I get out of. But for a toy??? When I pull the 4 banger out of my 93 Mustang to put the 351w in it, there will be a big carburetor sitting on top of it because I would rather be at the track playing rather than hunting down little efi issues or dyno tuning something. Carburetors when tuned right are pretty hard to beat.
And I can tell you from experience that EFI engines will eat you out of house and home and cause my wife to get a lot more pissed at me than a carburated one and I enjoy being able to tune at the track having fun rather than having to take it to someone that has the ability to tweak the computer every time I want to do anything. A EFI engine that is tuned perfect and every sensor is working great is a beautiful thing, but for a budget minded hot rodder you will NEVER convince me that EFI is a better choice. I can put a carbd motor in a mustang for virtually nothing compared to the cost of EFI.
$250 for a Moates QuarterHorse and the free TunerPro software will let you tune any and every single parameter on the '89-95 Mustang ECUs. A set of $80 42-lb/hr injectors, and a $25 Ford slot MAF in a 4" housing will support in excess of 500 RWHP if you want to go fast.
You don't need to take it to someone to change things, when A. A properly setup mass-air system will adapt to most common changes you make and B. Taking 20 minutes to learn the software will let you tune the engine yourself with a laptop or tablet.
