Oil recommendation - Ford Truck Enthusiasts Forums
Oil recommendation
Old 07-28-2012, 12:53 PM
dbreckman dbreckman is offline
dbreckman is starting off with a positive reputation.
Oil recommendation
I have both a 99 (5.4) and an 01 (4.6) F150 both are around 180k miles. I am about to do oil changes to both and I'm wondering if I should switch to a "high mileage" oil it if standard oil is still ok? Also I live in SE Texas but have so far only used the factory recommended 5W20 oil, should I go to a heavier oil due to the extreme outdoor temperatures?
Old 07-28-2012, 03:07 PM
Bluegrass 7 Bluegrass 7 is offline
Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.
Keep using the same as you have been.
There is no reason to change.
Going heavey is old school thinking.
The motor has oil pressured cam chain tensioners.
Using heavey oil puts excessive tension on them during cold starts.
The motor is not a push rod type.
Motorcraft oil has finally gone up in cost. It 'was' the best deal out there for a blended oil.
If you use some other 5w20 non blend, at least get the oil with a little more zinc for a little extra wear protection.
Some of the oils have seal expander additives.
Avoid them if you don't need it.
At the mileage you have, notice the oil will color quicker due to ring blow-by. A couple thousand miles after that it's time to change it and the filter each time.
Just for compairison, here in the notheast climate, I have been changeing every 5000 + for the life of the motor using 5w20 and MC filter.
The truck has been punished towing as high as 12,000 gross combined weight in dead heat of summer.
Oil pressure with an external gauge is nearly 70 plus at cold start, 25 at hot idle and nearly 50 hot normal running speeds
The motor is quiet as new at 176,000 miles.
Good luck for whatever it's worth.
Old 07-28-2012, 06:27 PM
00GT's Avatar
00GT 00GT is offline
00GT is starting off with a positive reputation.
I agree with bluegrass.. I've always used Motorcraft 5w20 and MC oil filter in both our 03 F150 4.6 and our 06 escape 3.0 never ever had an issue. Cheapest place is Walmart $18.33 for 5qt jug $4.37 for one qt and $3.97 for filter
95 5.8L engine oil pan Toplait 1987 - 1996 F150 & Larger F-Series Trucks 2 05-15-2015 01:38 AM
recommended oil viscosity f150 5L? Jromas 1987 - 1996 F150 & Larger F-Series Trucks 3 05-26-2012 08:17 PM
First Oil Change EburgHDFord EcoBoost (all engine sizes) 17 05-24-2011 11:19 AM
oil change question????? madda 2004 - 2008 F150 5 01-25-2010 03:53 AM
Transmission/Transfer Case Oil to Use? Monte Doenz 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 11-05-2005 04:11 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
