Factory ford Radios - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Factory ford Radios
Old 07-28-2012, 01:37 AM
95YJman 95YJman is offline
95YJman is starting off with a positive reputation.
Factory ford Radios
I have a 05 Ford F350 with the XL package, so its pretty basic stuff. I have the factory none CD player radio right now, my question is if I had access to a cheap factory radio with CD player could I just swap them out? Would I need a different wiring harness or anything?
These are the types of radio's I'm talking about
my current one
Old 07-28-2012, 06:55 AM
busdriver47 busdriver47 is offline
busdriver47 is starting off with a positive reputation.
It should work
Old 07-28-2012, 07:35 AM
RPM371's Avatar
RPM371 RPM371 is offline
RPM371 is gaining momentum as a positive member of FTE.RPM371 is gaining momentum as a positive member of FTE.
Yes. It should plug right in. You could also spend a couple hundred bucks on eBay for an aftermarket radio like I did and get all kinds of goodies like Bluetooth, DVD, backup cam and Nav. It also plugs right in to the existing wiring with an adapter.
Old 07-28-2012, 08:26 AM
Gage2502's Avatar
Gage2502 Gage2502 is offline
Gage2502 is gaining momentum as a positive member of FTE.Gage2502 is gaining momentum as a positive member of FTE.
Quote:
What brand radio is that??? I have been wanting to upgrade the factory radio, I was looking at a Kenwood but its hard to spend $1200 on a radio.
~Gage~
Old 07-28-2012, 09:15 AM
RPM371's Avatar
It's a nobrand Chinese radio I bought off eBay brand new for about $200. It has DVD, CD, iPod, mp3, USB, 2 cam inputs, TV, Bluetooth and GPS with a 7inch touchscreen. You can find them on eBay all day long! Buy a wiring harness and mounting adapter at Autozone and you're good to go. Takes less than an hour to swap them out. You have to pull the dash and remove 4 screws.
Old 07-28-2012, 01:46 PM
Gage2502's Avatar
RPM371, Ya I was just looking at them on eBay, Where did you install the GPS antenna at? Also how good is the sound, Maps?
One more thing I see it comes with a Touch Pen, can you use your finger to use it or just that Touch Pen it comes with?
Thanks ~Gage~
Old 07-28-2012, 02:53 PM
BPofMD's Avatar
BPofMD BPofMD is online now
Posting Legend
BPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputation
my current one
If you have access to a close model year, (05-06-07) it should just swap right out. Or if you have a little $ to spend, go with what the other guys suggest.
Old 07-29-2012, 12:30 AM
mlminor mlminor is offline
mlminor is starting off with a positive reputation.
It worked on my...
2008 F250 XL - I upgraded to a factory Ford 6 CD and it was plug n' play. $100.00 two years ago (ebay), still works great.
Old 07-29-2012, 03:29 AM
RPM371's Avatar
Thanks ~Gage~
I installed my GPS antenna near the defrost vent and routed the coax thru the dash. The sound is good thru my factory speakers. Not extremely thrilled with the maps that came with it, but that can be upgraded to Garmin. I have no problem using the touchscreen with my finger. I also put a screen protector on to keep it from getting scratched up.
For what it costs, it's a good radio.
Old 07-29-2012, 03:45 AM
Tylus's Avatar
Tylus Tylus is offline
Submarines Once....
Tylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputation
any radio from the following Ford/Lincoln/Mercury vehicles will work
2003-2008 Expedition/Navigator
2004-2008 F-150/Mark LT
2005-2009 Mustang
2005-2008 Superduty
there are more, but that's a pretty large segment of vehicles to pick from
as far as features, the 2007+ radios have an Aux input. Ford uses it with a headphone jack
Old 07-29-2012, 09:19 AM
Gage2502's Avatar
Thanks for the info....I didnt know you can upgrade the maps with Garmin, does that just require buying the Garmin maps and installing them?
Thanks again ~Gage~
51-52 Radio adapter kit 51PanelMan 1948 - 1956 F1, F100 & Larger F-Series Trucks 38 03-17-2015 10:38 PM
Proud owner of a '84 F150 XLT GOLD (pic heavy) '86 F150 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 17 12-16-2012 07:58 PM
bigun ctubutis Testing..... 6 09-23-2012 05:39 PM
PIE without PIE ~ Aux or Line In for MP3/iPod creator 1999 to 2016 Super Duty 1 04-13-2012 09:26 AM
Audio/Video Setup Installed Tylus 2007 - 2014 Expedition & Navigator 13 05-02-2010 07:54 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
