7.3L Oil Change
Here is a link that will give directions for the oil change and a few other things that you may be interested in doing.
Welcome to guzzle's Ford PSD Maintenance Web Page
Tim M
Tim M
Not really, it's pretty straight-forward.
Some of us will poke a hole in the bottom of the filter to let it drain to make it less messy when removing it.
Because the filter is so large and holds so much oil, most of us will pre-fill the filter before spinning it on.
I'd suggest you get a Fumoto valve with a nipple Riffraff Diesel: Fumoto Quick Drain Valve W/ Nipple so you can pop a hose on the end and drain it right into your recycle container.
You know how much oil these beasts take, right?
Stewart
Stewart
I have one on my Chrysler Town & County and have had one on most every vehicle that I've owned. So much nicer when oil-change time comes around!
Wagion
1999 to 2016 Super Duty
49
03-28-2011 07:29 AM
RedTaurus94
06-23-2003 08:00 PM
