400 pistons in a 351m
I have heard of all kinds of ways to raise the compression for the 351m/400 engines and was wondering if it would be possible to shave the top or the crown of stock 400 dished pistons to fit a 351m? basicly machining a flat top piston for the 351m to raise compression. it seems like it would be cheaper and less involved than milling heads,blocks, intakes, and shorter pushrods that are involved with shaving or milling a significant amount from these motors.
Well I was wrong, the 400 piston will not work in the 351m, the 400 piston has a shorter compression height. but the 351m piston with 0.3 shaved from the top will make for 0 deck height in a 400. (not sure about the valve reliefs though)
Still wondering if stock milled 351m pistons would be a cheaper alternative to custom pistons for a 400 build?
the compression height (distance from wrist pin centerline to piston top) of 351C pistons is compatible with 400 pistons. Stock compression heights of the various 351C pistons range from 1.631" to 1.657". The compression height of the stock 400 piston is 1.650". (Remember, the 351M uses the same rod as the 400 with 0.50" less stroke, so its piston compression height is much taller than the 400 piston to make up for the different stroke with the same rod. The 351M piston compression height is 1.947".)
WARNING: Pistons are not interchangeable between the 400 and 351M. If you used 400 pistons in a 351M, the piston top would reach TDC at more than 0.3 inch below the deck surface and you would have a compression ratio of only about 5.5:1. If you use a 351M piston in a 400, it will smash into the head because it's top surface is about 0.3 inch above the deck surface.
79bronco99pwrstroke
04-08-2004 11:35 AM
Mil1ion
11-13-2002 02:26 PM
