Ford parts
Old 07-27-2012, 07:08 PM
pin8246's Avatar
pin8246
pin8246 is offline
Ford parts
Anyone have any info on any dealerships that parts are cheaper? Or aftermarket that fits like stock? Time to start cleaning up the truck and get some little odd and ends to get it back right. Example like door panels, rear bumper steps, rear tailgate.
Thanks for any info.
Old 07-27-2012, 07:29 PM
SGPI's Avatar
SGPI
SGPI is offline
I see TASCA Ford on the board alot. I cannot give firdt hand experience yet but I have ordered some parts and the prices are good.
ood luck getting your truck clean up.
Old 07-27-2012, 07:40 PM
GonzoCSU's Avatar
GonzoCSU
GonzoCSU is offline
I got my oem glow plugs and UVCH from RockAuto Parts Catalog
Someone on the boards suggested them, they have good prices. I was a happy customer.
Old 07-27-2012, 09:32 PM
BigAlsPSD's Avatar
BigAlsPSD
BigAlsPSD is offline
Tousley Ford Parts Depot is another that is a dealer with decent pricing.
Old 07-27-2012, 11:31 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
Plus, Tousley is a supporting vendor here at FTE.
Let's also remember Clay at Riffraff Diesel has some OEM parts too, and he's DEFINITELY the first stop you wanna make for aftermarket parts. Riffraff Diesel Performance Parts | Ford 7.3 diesel | 7.3 powerstroke | Ford Powerstroke | 7.3L Powerstroke Parts
Stewart
Old 07-28-2012, 12:43 AM
WA.Ranger's Avatar
WA.Ranger
WA.Ranger is offline
Stewart
That's my one stop shop!
Old 07-28-2012, 12:53 AM
PaysonPSD's Avatar
PaysonPSD
PaysonPSD is offline
Your best bet for body parts is a salvage yard.
As for a tailgate, 1999 thru 2010 will fit.
There are many body parts, including head lghts and tail lights, etc..., from 1999-2007 that fit or fit with minimal modification so don't limit yourself to your trucks model year.
As for aftermarket some are good, some bad. Ask here before you buy.
Ask about other model year parts as well.
Word of caution. Never buy aftermarket CPS or Glow Plugs. Motorcraft or International only on these two.
Old 07-28-2012, 07:14 AM
Tugly's Avatar
Tugly
Tugly is offline
Tailgate. I saw a new tailgate (with the "SUPERDUTY" across the bottom) on a 2002 SD. The tailgate fit, but the tail lights didn't match the contours, it take spring hardware to install it, and the top lip with the ladder is cool - but good luck ever buying a cover for the bed (like a canopy).
Old 07-28-2012, 12:58 PM
PaysonPSD's Avatar
PaysonPSD
The tailghts match the contour of the bed, not the tailgate. That should not be an issue. Unless the tail lights you saw were some bad aftermarket ones.
I have a 2008 non-step tailgate and a Snug Top hard tonneau meant for a 2008 with step tailgate. Except for a slight overhang it seals just fine. It seals to the top straight portion on the tailgate. It would be easy to find a canopy to fit since the boxes are identical and you can by a canopy for a truck with or without a step tailgate.
2008 tailgate and 2008 tail lights.
Old 07-28-2012, 02:08 PM
bkuuz1's Avatar
bkuuz1
bkuuz1 is offline
Will a cap fit normal on the beds if you change the tailgate? I have been thinking about changing mine out but I might also want to get a shell too.
Old 07-29-2012, 07:56 AM
Tugly's Avatar
Tugly
Tugly is offline
...2008 tailgate and 2008 tail lights.
You mention you put the same year tail lights as the tailgate on your truck. This is what I was thinking - old tail lights with new tailgate looks wierd. Did I get confused?
Old 07-29-2012, 12:20 PM
PaysonPSD's Avatar
PaysonPSD
If you order the shell properly no problem. If you install a non-step 2008 tailgate make sure they no this when buying a shell. They would then order a shell for a 2008 with non-step tailgate. If it is a tailgate with step (the tailgate is thicker in the middle and bows out more than a non-step tailgate) make sure they know that. If they are experienced and you tell them what tailgate you installed they should know what to order.
I guess I got confused.
I had actually installed the 2008 tail lights about a year before installing the newer tailgate. LINK
Old 11-16-2012, 01:19 PM
Y2K1TON's Avatar
Y2K1TON
Y2K1TON is offline
If you want factory parts try these guys. I use them all the time. I live in TX and the prices with shipping are still lower than local prices. Their customer service is top notch too.
https://www.silverstatefordparts.com/login.html
Old 11-17-2012, 12:46 AM
Stewart_H's Avatar
Stewart_H
They're almost as cheap as Tousley Ford Parts.
Stewart
Supercab
10-25-2018 07:47 PM
wfoskir
1999 to 2016 Super Duty
08-27-2018 08:13 AM
P Munson
10-23-2010 07:23 PM
BBatty2004
Escape & Escape Hybrid
08-10-2004 09:33 PM
karljay
Paint & Bodywork
07-08-2001 06:40 PM
Quick Reply: Ford parts
