I drained the fuel bowl and cleaned it up, I added Stabil to it when I fill up, It ran good still is and the WIF light never came on after, but now it's decided to pop back on and I don't know why, I took it on a trip to lousiana awhile back and i never had it come on. suggestions>?
Take the fuel filter out and put the cap back on. Let it sit overnight and take a syringe fitted with a small hose and slowly push the hose to the bottom of the fuel bowl and suck of the bottom and see if you get water or fuel
Well, driving hoem last night I was using my rear gas tank, and it was low on fuel but the low fuel light never came on and i hit on the pedal and i was just decreasing speed and the engine would rev just no power... Pulled to side hazards switched fuel tanks, and shut it off cause it was shaking turned it back on after letting it sit a few and drove home and it drove fine.. whats going on?? ABS light turned on also strangely... I turned it off and on and it just went off and never came back on.
Sounds like you ran the rear tank out of fuel...........we don't have low fuel lights.
So what exactly is making my Water in Fuel come on, I threw in seafoam, Stabil, I drained the fuel bowl, I replaced the fuel filter. Is it the sensor? Or should I just flush the whole fuel system? It was sitting for a bit before we bought it from the owner.
I caught that too bro, but read between the lines as well. *shrugs*
Sorry William but Im with Rodney. He wrote: "Well, driving hoem last night I was using my rear gas tank, and it was low on fuel but the low fuel light never came on"
