88 F250 inner U joint on front suspension
How do I remove the inner U joint on the front suspension on the driveshaft that runs from the drivers side to the passenger side? I realize its a clip on the inside but mine is so rusted I am having an extremely hard time getting it out. Any ideas or tricks?
No. The u joint directly to the right Of the slip yoke and stub shaft as seen in the picture in the link
http://www.therangerstation.com/tech...agrams/as2.GIF
I need to get the slip yoke to go back over the right shaft. After trying for quite a while it seems i need to remove that u joint so I can slide the slip yoke over the right shaft.
on
If I'm following you, the slip yoke came apart and the rest of the axle is still intact. That shouldnt happen unless something is very wrong withh your front end. To put it back together, remove the caliper, rotor, spindle, then the outer axle can be removed and splines re-engaged. Here's member Encho's writeup: https://www.ford-trucks.com/forums/1...l#post11243835
rcnease
10-29-2013 05:03 PM
wiggins
07-28-2011 11:29 AM
bigb9582
06-29-2011 02:14 PM
shemp
09-22-2003 09:40 PM
