power steering pump
power steering pump
i have a 1978 f150 and just replaced the power steering pump and hoses, the pump is the older metal one with the tiny dipstick like a trans ( my 1970 f250 had this same pump) and not the large plastic one like it should so i put the same style pump as it had one it when i replaced it, it has been on there a week or so and i still have no power assist, i have jacked it up several time and turned the wheel left to rite several times to work the air out of the system and when it seems to get better than its like it just starts over back to were it was where it will not hardly turn at all ? the pump is brand new i cannot figure out why its doing this ? i may just go buy another ( the rite year specific pump this time)
I have a 1978 F150 and just replaced the power steering pump and hoses. The pump has the older metal reservoir (my 1970 F250 had this same pump) and not the plastic reservoir like it should.
So I put the same style pump as it had one it when I replaced it, it has been on there a week or so and I still have no power assist.
The P/S pressure hose has a straight tube with an O-ring on it at the pump end. Connects to the pump with a qwik connect fitting.
1965/77 FoMoCo vehicle P/S pumps have a steel reservoir. The P/S pressure hose threads directly onto the pump.
The plastic reservoir pump is smaller in diameter than the steel reservoir pump. Besides the different plastic reservoir only P/S pressure hose, the pumps mounting brackets may be different.
Thanks for the info numberdummy i am aware of this, i was saying my 78 has the wron pump, resivour, pulley, bracket and belt ie. The whole shabang and was wondering if there was a trick to bleeding the air out of these older style ones, the newer ones with the plastic resivour seem to bleed them self out quick enough
I forgot to mention that you need to turn the engine off while you leave it set several minutes on each lock.
wotan
05-15-2018 09:51 AM
rubber_city_cowboy
05-26-2012 08:42 PM
octaneforce
10-20-2009 07:50 PM
svdweb1
08-02-2004 03:04 PM
