A little cylinder head ID help - Ford Truck Enthusiasts Forums
Old 07-27-2012, 03:52 PM
stickbow9 stickbow9 is offline
stickbow9 is starting off with a positive reputation.
So the truck I just picked up has a 351m by the VIN number but the PO says "oh yeah it's a 351c". I know this couldn't be the case and it was not even a factor really anyways. I am tryin to research the components and I have found a Weber/Carter/Edelbrock 4bbl carb, an Edelbrock intake manifold for the 400, and aftermarket exhaust from the manifolds back. I was hoping for some help with identifying the cylinder heads without removing the valve covers. I am wondering what the significance of the stamp on the front of the drivers side head is . . . 5771. Probably not helpful, but this truck runs very strong and I am thinking there is a chance that one of the PO's rebuilt it as a 400. That would be cool as I eventually planned that anyways and it would save on component costs. Any help would be appreciated.
Old 07-31-2012, 08:33 PM
crsmiffy crsmiffy is offline
crsmiffy is gaining momentum as a positive member of FTE.
hey not much love here yeah? you could try checking the stoke down the plug hole to see if it is a 400. 4" is a 400, approx 3.5" is a 351M. Cant help with the heads, but old mate before you has done most of the good work on the intake and exhausts, so thats a good thing.
Old 07-31-2012, 11:50 PM
Yeah for sure on the previous owner(s) doing all the other stuff. Thanks for the stroke info. I have been reading that but totally spaced that part.
Old 08-01-2012, 02:07 AM
CS79bronco CS79bronco is offline
CS79bronco is gaining momentum as a positive member of FTE.
If they are Cleveland heads they will have "2" or "4" cast into the top left corner just outside the valve cover. Look at the drivers side head, easiest to see. I have seen a few heads with "M" in that spot, but most are just plain. If it is a Cleveland, the intake will be different from the "M" block motors. If you have a Performer 400 intake on there you have the "M" motor. As smiffy said, checking the stroke is the quickest way to tell if 351 or 400. Otherwise it's drop the pan & check the casting number on the crank. No fun there. If the PO installed a decent cam & straight up timing set when it was rebuilt you got a good one.
Old 08-01-2012, 01:01 PM
Sweet thanks. I feel like tackling a two piece rear seal change soon so I will check crank then.
Edelbrock/Weber on a 1969 390 crappy idle when its hot out packrat56 1948 - 1956 F1, F100 & Larger F-Series Trucks 19 07-08-2014 08:53 PM
General crankcase vent question stickbow9 1973 - 1979 F-100 & Larger F-Series Trucks 4 07-26-2012 11:55 AM
Triple Deuce ssj7kids 1948 - 1956 F1, F100 & Larger F-Series Trucks 48 06-04-2011 02:08 PM
who has a Weber carb? 351 power Fuel Injection, Carburetion & Fuel System 2 10-15-2003 02:10 PM
Another pair of questions. JSWF100 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 2 08-14-2000 04:27 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
