Worn rear end on 96 SC 4x4
I was looking for a "squak-squeak" noise (u-joints I think), and I noticed alot of slop (and a leak) where the drive shaft connects to the differential. I posted a short video clip on flickr. Could someone possibly help diagnose? What's involved in the repair?
1996 F150 Supercab 4x4
http://www.flickr.com/photos/cocojen...7630776635096/
Thanks!
Thanks!
I should have been more clear, sorry. I would take it to a shop to have them see if tightening the nut is possible. If they do it correctly, including using a crush sleeve, then they need to use an inch-pound torque wrench with the carrier removed to set the pinion bearing preload. There is also the 'close enough' method where you just hammer the pinion nut with the biggest impact wrench you can find and hope it's close. The pinion nut requires an enormous amount of torque to set. You will not be able to get it tight enough laying on your back with hand tools.
Ok, done a fair bit of reading on the subject now (makes me no expert of course).
Any way to tell if the bearings are toast? Rumble I suppose?
I'm pretty sure the seal needs to be replaced, but from what I've seen it is not a tough job. I am unable to "count threads" or mark the pinion nut orientation (so as to get the nut back exactly as it came off) since apparently the nut has backed off from where it was originally. I'm guessing that the preload is un-re-attainable at this point without installing a new crush sleeve. If the bearings are still good however, should I not just have to install the crush sleeve and adjust the pinion nut with in/lb (dial or beam type) torque wrench? Wouldn't the backlash and pinion depth stay the same with existing shims?
I haven't had a chance to look for someone to set it back up for me, and still considering the possibility of having that done if the cost doesn't send me into too deep a shock.
on
Here's what I've always done in this situation:
disconnect driveshaft.
Check for play up and down/side to side in the pinion.
If there is play try to tighten the nut to remove play. You wont be able to get it too tight by hand, the crush sleeve is pretty tough to crush.
If you still have play your bearings are bad
Remove nut and pinion flange, then pop the seal out and replace
replace flange and nut, tighten as tight as you can by hand.
Listen for rumbling, particularly one that comes and goes with throttle.
guessrow
05-07-2007 04:35 PM
lpapetti
31
10-14-2006 10:06 PM
