Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 07-27-2012, 07:44 AM
hobbs53's Avatar
hobbs53 hobbs53 is offline
Garage is empty, add now
hobbs53 is starting off with a positive reputation.
gas coming back out filler tube on '59 Fridge
i filled up the tank on the Fridge, parked it in the garage, came back later, and gas was expanding up the filler tube and running down the side of the truck......any help solving this problem?
Thanks!!
  #2 (permalink)
Old 07-27-2012, 06:49 PM
59 shorty's Avatar
59 shorty 59 shorty is offline
59 shorty is starting off with a positive reputation.
vent it. After market cap on it now like a locking one or something off of something else you had? Hot envirement like warm garage or sun light and gas expands. Have you had this problem before or has something changed to your gas tank or cap? Mark
  #3 (permalink)
Old 07-27-2012, 07:17 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a good reputation on FTE.spurredon has a good reputation on FTE.
You just can't fill it so full when it is hot out! It is pretty scary to come out and find your truck covered with gas isn't it? I have had the pleasure.
  #4 (permalink)
Old 07-27-2012, 08:18 PM
hobbs53's Avatar
Mark, the cap was on the truck when i got it...it's a locking cap...i assumed it was a "stock replacement", but i don't know for sure. I haven't had this happen since i had the tank cleaned, baffle and return line installed (for the fuel injection), so i don't know if it'll do it again; so, getting a "vent" cap would solve this? I'd really like to keep a lock cap on it......; i remember (in days gone by) syphoning gas..don't want that to happen to the fridge..... ...spurredon...yea, VERY scary......
thanks guys!!....really appreciate your thoughts! scott
  #5 (permalink)
Old 07-28-2012, 06:55 AM
Walston's Avatar
Walston Walston is offline
1960 Ford F-100
Walston has a good reputation on FTE.Walston has a good reputation on FTE.Walston has a good reputation on FTE.
Buy non-expandium gasoline. It is hard to find. This particular gas violate the laws of physics and does not expand when it's temperature is increased.
Obviously I am kidding, you just can't fill the tank quite so full in the summer time.
__________________
Walston
http://bigjohnstractor.com/
  #6 (permalink)
Old 07-28-2012, 10:22 AM
willowbilly3 willowbilly3 is offline
willowbilly3 is gaining momentum as a positive member of FTE.
It can be a problem anytime but worse in the summer. I never top the tank off and never park on an angle with the drivers side lower. Just get used to listening when you fill and you can hear when it's getting full, stop before the pump shuts off. Those caps have to be vented both ways because there is no other vent on the tank.
  #7 (permalink)
Old 07-28-2012, 07:09 PM
spurredon's Avatar
A vent won't solve the problem of overfilling. There is very little area between the top of the tank and the top of the fill neck. If you run gas up into the neck (often where the gas pump trips off), it is bound to come out when it expands.
Doing a little digging around on the net shows that gasoline expands at a rate of 0.069% per degree Farhenheit. If you pump gas out of an under ground tank that is only 60 degrees and put it into a tank that is setting in 95 degrees, it will expand roughly 2.4 percent. So if you fill your standard 18 gallon tank on a day like this it becomes a little more than 18.4 gallons. I don't think the fill neck will hold much more than a quart so there you go! Prolly all my math is wrong but we all know that it expands and runs out if you get it too full so something must be happening somewhere!
  #8 (permalink)
Old 07-30-2012, 05:33 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
If the locking gas cap wasn't vented, you would have known this the second it was removed. Using a non vented cap causes pressure build up, so there would have been a loud whooshing sound when removed.
Using a non vented cap on these trucks not only causes pressure build up, but could also cause the tank to partially collapse.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
  #9 (permalink)
Old 07-30-2012, 07:37 PM
hotfalcoon's Avatar
hotfalcoon hotfalcoon is offline
1957 Ford F-100
My Garage
hotfalcoon is starting off with a positive reputation.
The O.P. stated that he is running fuel injection. A.F.A.I.K he should be using a non vented cap to keep the proper pressure for the fuel injection and the return line back to the tank would keep the tank from collapsing.
  #10 (permalink)
Old 07-30-2012, 08:01 PM
arctic y block's Avatar
arctic y block arctic y block is offline
Old School
1962 Ford F-100
arctic y block has a spectacular reputation.arctic y block has a spectacular reputation.arctic y block has a spectacular reputation.arctic y block has a spectacular reputation.arctic y block has a spectacular reputation.arctic y block has a spectacular reputation.arctic y block has a spectacular reputation.arctic y block has a spectacular reputation.arctic y block has a spectacular reputation.arctic y block has a spectacular reputation.arctic y block has a spectacular reputation.
Quote:
That's just about what I was gonna say. Thanks.
__________________
85 XLT Bronco 351W HO 4V Dual Pipes 33X12.5 BFG's
62 Uni 390 C6 Custom Cab Not Yet Sold
Looking to buy a 48/50 F Anything If ya have one contact me.
Don't just Modify it Fordify it
  #11 (permalink)
Old 07-30-2012, 09:12 PM
theodore/teddy's Avatar
theodore/teddy theodore/teddy is offline
theodore/teddy is gaining momentum as a positive member of FTE.
The tank needs to vented somehow, to replace the volume of fuel used by the engine process. New systems use charcoal canisters and purge valves.
Just a random thought. Carry on.
__________________
1959 F250 4x4
Wally
  #12 (permalink)
Old 07-31-2012, 09:10 AM
hobbs53's Avatar
thanks for all the feedback guys....great points.. the cap is "loose" so it's vented...sounds like the easiest thing to do is just not fill it rather than adding a charcoal canister and purge valve, if that's an option with the fuel injection. will that work?
  #13 (permalink)
Old 07-31-2012, 10:45 AM
Hobbs the charcoal can and purge valve are more an environmental thing, dealing with the fumes while allowing the tank to breath. As Spur (and others) pointed out I think your spill issue can be resolved by not topping the tank off before storing the truck.
__________________
1959 F250 4x4
Wally
  #14 (permalink)
Old 08-01-2012, 11:01 AM
While proper venting is a must, tank pressure isn't required for the fuel injection to function. If you are using the original tank your options are few. You must use the cap that is vented both ways and those are kind of hard to come by in the parts stores. And you just can not top off the tank. Your best bet would be to get rid of that tank and put one between the frame rails in the rear. Do some measuring and hit the junkyards. A tank from a Jeep might fit good. I had one from a suburban that fit between the frame rails on my 69 but the Chevy fuel gauge runs on a different ohm range than a Ford so you have to deal with that. Another option is to measure what size you need and have a sheet metal shop brake the metal so it only takes 2 pieces to make a tank. Then anyone who is a decent welder can tig or mig the tank together.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
