Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2009+ F150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2009+ F150 Discuss the 2009, 2010 and new 2011 Ford F150 SPONSORED BY:
  #1 (permalink)
Old 07-26-2012, 06:23 PM
shortride's Avatar
shortride shortride is offline
2010 Ford F-150
shortride is gaining momentum as a positive member of FTE.
How about an aluminum F150?
700 pounds lighter, Yikes!!!!! I'm saving for it starting right now.
Ford Plans New F-150 Pickup Truck With Aluminum Body
__________________
2010 XLT 4.6 Screw
Vietnam Combat Veteran - 11F40
  #2 (permalink)
Old 07-26-2012, 06:44 PM
Lead Head Lead Head is offline
Garage is empty, add now
Lead Head has a great reputation on FTE.Lead Head has a great reputation on FTE.Lead Head has a great reputation on FTE.Lead Head has a great reputation on FTE.Lead Head has a great reputation on FTE.
I'm guessing the bed will steel be steel, or at least have steel inserts on the inner walls and load floor.
I don't really see any issue with an aluminum body or chassis as long as it's designed and built correctly. Peterbilt has done/does it.
__________________
- Ian
1987 Ford Ranger XLT 4x4 2.9
Needs a lot of work, including some rot on the body, but shes getting there.
  #3 (permalink)
Old 07-26-2012, 06:53 PM
tseekins's Avatar
tseekins tseekins is offline
2011 Ford F-150
tseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputation
The super structures of Coast Guard and Naval ships are aluminum skinned with steel ribs. Light and easier to maintain.
The hood on my Expy was damaged a couple of years ago by my daughter's basketball hoop. The hood could not be repaired, it required a complete replacement. $1100.00 for the hood alone.
The repairs will kill any savings and will likely force the auto insurance industry to possibly raise rates due to the complexity of repair or the cost of replacing body panels. My personal opinion here.
__________________
Tim
SCPO United States Coast Guard Retired
2011 F-150 XLT 4x4 Ecoboost
2010 Ford Focus
2004 Expedition XLT 4x2
FTE Guidelines
  #4 (permalink)
Old 07-26-2012, 06:58 PM
Working with aluminum is really not that difficult. It can be bent, beaten, hammered, ground on, welded and sanded just like steel. It's for the most part actually easier to work with then steel. It just requires slightly different tools and technique.
If aluminum takes off, more body shops will get the tools necessary to work on aluminum.
__________________
- Ian
  #5 (permalink)
Old 07-26-2012, 07:18 PM
FlatBlak FlatBlak is offline
2000 Ford F-150
FlatBlak is starting off with a positive reputation.
they shouldve done this about 80 years ago
  #6 (permalink)
Old 07-26-2012, 07:37 PM
smokewagun smokewagun is offline
smokewagun is starting off with a positive reputation.
I'm not hanging my hat on this one. After seeing how long Ford has had issues with the paint on their aluminum liftgates, I wonder if they'll get the paint prep process right. I can see a year or two (maybe) of wiling on the issue, but after that, it's rediculous. A $55-60k truck with cancer after three years is not right. I'm all on board of they prove themselves. Of course, well all be pushing aluminum someday, I'll bet. What ever happened to the plastic body panels?
  #7 (permalink)
Old 07-26-2012, 08:49 PM
Tylus's Avatar
Tylus Tylus is offline
Nuke Mechanic
2006 Ford F-250
Tylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud of
God I hope not. Ford has enough issues getting their current aluminum panels to stay painted as it is.
FYI, Ford has been running aluminum hoods and rear hatches since around 2004. It's been 8 yrs and they still corrode pretty regularly within the 1st year
the weight savings would be nice though
__________________
MM1 (SS) - 688 Class - First Flight Tough
2006 F-250 Lariat CC w/PSD <-- Build Thread
2012 Flex Limited <-- 17 mpg city, 27 mpg highway.
  #8 (permalink)
Old 07-26-2012, 08:50 PM
FORD COASTIE's Avatar
FORD COASTIE FORD COASTIE is offline
2012 Ford F-150
FORD COASTIE is gaining momentum as a positive member of FTE.FORD COASTIE is gaining momentum as a positive member of FTE.
Quote:
Tim,
I sure hope Ford takes the extra steps to prevent dissimilar metal corrosion if they don't build the entire truck out of aluminum. The Coast Guard has not done a good job with this, and it has cost taxpayers a lot of money in repairs to our ships over the years because of it. Our fine Naval Engineers still haven't figured out the simple things like you can't use stainless steel hardware to attach aluminum components to an aluminum superstructure, and mild steel doesn't work well when you bolt it straight to aluminum without any sort of barrier to keep them from touching one another.
__________________
2012 F-150 XLT Super Crew 5.0
  #9 (permalink)
Old 07-26-2012, 08:54 PM
tseekins's Avatar
2011 Ford F-150
Quote:
Originally Posted by FORD COASTIE View Post
Tim,
I sure hope Ford takes the extra steps to prevent dissimilar metal corrosion if they don't build the entire truck out of aluminum. The Coast Guard has not done a good job with this, and it has cost taxpayers a lot of money in repairs to our ships over the years because of it. They still haven't figured the simple things like you can't use stainless steel hardware to attach aluminum components to an aluminum superstructure.
Yeah, I know what you're saying bro. Three submarines and four CG Cutters in my resume and they still don't learn. Will Ford?
__________________
Tim
2010 Ford Focus
FTE Guidelines
  #10 (permalink)
Old 07-26-2012, 09:03 PM
2012 Ford F-150
Glad to see I'm not the only Permanent Cutterman on these boards. Lol.
__________________
  #11 (permalink)
Old 07-26-2012, 11:00 PM
Guys, It's not like bolting aluminum and iron/steel components together is something new in the automotive world.
Aluminum heads on iron blocks. Aluminum thermostat housings on iron intakes. Aluminum intakes on iron heads. Aluminum transmissions to blocks, aluminum transfer cases to iron transmissions. Aluminum IRS differentials to steel chassis. Aluminum control arms to iron knuckles, etc...Yes there have been issues, but you are making it sound as if components are going to be falling off within a few years...
These trucks are not sitting in a bath of salt water 24/7.
The Ford hood issue turned out to be from iron particles getting on the aluminum panels before they were painted. My friend has a '98 Ranger with a factory aluminum hood. No excess corrosion on it or peeling paint.
__________________
- Ian
  #12 (permalink)
Old 07-26-2012, 11:33 PM
Onus's Avatar
Onus Onus is offline
1990 Ford F-250
My Garage
Onus is gaining momentum as a positive member of FTE.
I'll buy one. No more rust problems! Good enough for me.
__________________
Tanner - Connecticut Chapter Member.
1983 F-250HD 2wd 300. T18 4speed 4.10s. Base. 170k Hiding in garage for the last 10 years. dead. dads truck. Project truck.
1991 F-250HD 4x4 351w ZF 5speed 4.10s Custom. 165k old plow and landscaping truck. Parts truck.
1990 F-250HD 2wd 7.3idi e4od 3.55s. Custom 346k 'The Carpathia' Daily driver.
  #13 (permalink)
Old 07-26-2012, 11:35 PM
2000 Ford F-150
Could be wrong but I thought my harley davidson truck has an aluminum hood, and my gf's lightning does too doesn't it? Her dads mustang for sure does and all of them have no paint problems after 12 years, the mustang only 6
  #14 (permalink)
Old 07-27-2012, 01:53 AM
j.grif's Avatar
j.grif j.grif is offline
j.grif is starting off with a positive reputation.
A couple of things, my 97 f-150 had an aluminum hood, never had any problems with it in the 7 years I owned it, audi has been making cars out of it for at least 10 years on the tt if I am not mistaken, all that said, I work in the trucking industry in s.e. mi, the chemicals that wayne county put on the roads in winter eat the equipment up big time, air bag pedistals, fuel tank corrosion issues etc, I think if they apply the correct paints and primers it may not be an issue for rocker panels and floor boards, but at this point I would be a little skeptical about such a vehicle in the northern tier of states, just my thoughts!
  #15 (permalink)
Old 07-27-2012, 02:32 AM
AlaskanEx's Avatar
AlaskanEx AlaskanEx is offline
2002 Ford Excursion
AlaskanEx has a spectacular reputation.AlaskanEx has a spectacular reputation.AlaskanEx has a spectacular reputation.AlaskanEx has a spectacular reputation.AlaskanEx has a spectacular reputation.AlaskanEx has a spectacular reputation.AlaskanEx has a spectacular reputation.AlaskanEx has a spectacular reputation.AlaskanEx has a spectacular reputation.AlaskanEx has a spectacular reputation.AlaskanEx has a spectacular reputation.
my 98 expedition hood is good after 14 years and original paint. but i have repaired/painted a few 03-06 expedition hatches with corrosion issues. weird.
it will be interesting to see if the weight savings will make a marked improvement.
__________________
Russ-
02 Excursion Limited V10 4x4, 2.5/2" lift, HIDs,20" DC wheels on Cooper LTZ, Daily Driver
01 Explorer XLT Sport V8 AWD
98 Expedition XLT 5.4 4x4,HIDs,16x8 ultra wheels,led taillights, Daily Driver
91 F-250 lairat 4x4 5.0, 7'6" BOSS snow plow, Back Rack, Strobes, Work lights
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
