Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 07-26-2012, 03:21 PM
99hosss 99hosss is offline
1966 Ford F-250
99hosss is starting off with a positive reputation.
f-250 brake shoe
Hello Forum, I'm not trusting the auto parts guys on this question- when I buy a set of front/back shoes for the 60- f-250, is it a standard set, or are the backs larger? I know one side is larger, but is that the case all the way around? thanks
__________________
My addiction- wire brushing rust
  #2 (permalink)
Old 07-26-2012, 05:32 PM
F250racer's Avatar
F250racer F250racer is online now
Garage is empty, add now
F250racer is starting off with a positive reputation.
Not 100% sure but I believe that for that truck all four are the same shoe, meaning the set for the rear axle and the set for the front axle should be the same NAPA part number. The only difference should be at each drum, meaning for the right front drum one shoe will be slightly different than the other. I think one will have a little less pad or be tapered off a little differently.
__________________
Colin
'59 F-250 Styleside Longbed, 292, 4spd, Rockwell 5.83 dually running gear, custom NP205 overdrive.
"The truck's a Ford and the tractor's green"
  #3 (permalink)
Old 07-26-2012, 06:21 PM
theodore/teddy's Avatar
theodore/teddy theodore/teddy is offline
theodore/teddy is starting off with a positive reputation.
Not sure if I follow just what your question is. Each drum should have a primary and secondary shoe primary(short lining) to the front, secondary to the rear.
Good luck in your quest
__________________
Looking for an in bed spare tire mount for styleside fridge bed.
1959 F250 4x4
Wally
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
