Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1961 - 1966 F-100 & Larger F-Series Trucks > 1961 - 1963 F100 Unibody
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
View Poll Results: What year model is my F100?
1961 11 91.67%
1962 1 8.33%
1963 0 0%
Voters: 12. You may not vote on this poll
  #1 (permalink)
Old 07-26-2012, 11:19 AM
m00n m00n is offline
Garage is empty, add now
m00n is starting off with a positive reputation.
F100 Barn Find - Year??
Well found an all original F100 Custom Cab in one of my Moms barns. I plan on fixing it up, thing seems to be in great shape for its age, pretty much no rust at all except for a small spot on the hood. Either way, I'm having trouble figuring out what year it is. The VIN plate in the glove box is in perfect condition and has everything stamped EXCEPT the year. I've decoded the VIN that was stamped in the glove box and came up with this:
F10CD140504
F10 = F-100/2WD
C = 292ci 2 valve V8
D = Dallas, TX (Its been in the DFW its entire life!!! )
140504 = Unit Number
As you can see none of which gave me a production year. Is there any way I can narrow down if it was a '61, '62, or '63??
here is some pictures:
Click the image to open in full size.
  #2 (permalink)
Old 07-26-2012, 11:53 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by m00n View Post
Well found an all original F100 Custom Cab (see post 4) in one of my Moms barns. I plan on fixing it up, thing seems to be in great shape for its age, pretty much no rust at all except for a small spot on the hood. Either way, I'm having trouble figuring out what year it is. The VIN plate in the glove box is in perfect condition and has everything stamped EXCEPT the year. I've decoded the VIN that was stamped in the glove box and came up with this:
F10CD140504
F10 = F100 2WD
C = 292 2V
D = Dallas, TX Assembly Plant.
140504 Unit Number (Numerical Sequence of Assembly, the trucks specific serial number).
Welcome to FTE
Whatever VIN decoder you used didn't include: 140504 = 1961 .. Assembled February 1961.
Didn't include the following from the Warranty Plate either:
122" Wheelbase.
J = Rangoon Red
F100 = F100 2WD, 5,000 lbs, GVWR
A = Ford 3 speed Light Duty Manual Transmission.
11 = Ford 9" Rear Axle / 3.70-1 / no Limited Slip / 3,300 lbs. Rear Axle Capacity.
5,000 lbs. Gross Vehicle Weight Rating.
135 net HP @ 3,800 RPM
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
  #3 (permalink)
Old 07-26-2012, 12:04 PM
Quote:
Originally Posted by NumberDummy View Post
Welcome to FTE
122" Wheelbase.
J = Rangoon Red
11 = Ford 9" Rear Axle / 3,70-1 / no Limited Slip / 3,300 lbs. Rear Axle Capacity.
Thank you verrryyy much sir!
  #4 (permalink)
Old 07-26-2012, 12:09 PM
Ford Parts Guru
2013 Ford Escape
You've been mis-informed inre to what a Custom Cab is.
Your truck is not a Custom Cab, it's a Standard Cab.
1961 Custom Cab: Chrome steel grille & headlamp doors. Standard Cab, painted steel grille and painted headlamp doors / 1962/66 Custom Cabs have anodized aluminum grilles.
1961 only: The grille has FORD within it, upper grille panel is plain. 1962/64 upper grille panels have chrome FORD letters.
1961/66 Custom Cabs have stainless steel windshield reveal mouldings and Custom Cab nameplates on the doors, foam rubber seat cushions.
Standard Cabs & 4WD's have a horn button. Custom Cabs have a horn ring. Standard Cabs have a painted instrument cluster bezel with a round speedometer.
Custom Cabs have a chrome instrument cluster bezel w/a round speedo...except 1965/66 F100/250 2WD Custom Cabs that have a plastic chrome 'sweep speedo' instrument cluster.
Custom Cabs have R/L padded sun visors and R/L door armrests. Standard Cabs have a left unpadded sun visor and left armrest.
__________________
  #5 (permalink)
Old 07-26-2012, 12:18 PM
1961/66 Custom Cabs have stainless steel windshield reveal mouldings and Custom Cab nameplates on the doors.
Hence the reason I said it was a CC.. Has the badges on each door, so i just assumed. I'm pretty sure it is a CC though. I will have to double check.
  #6 (permalink)
Old 07-26-2012, 12:33 PM
Ford Parts Guru
2013 Ford Escape
Hmm...Tis hard to make out the R/door Custom Cab nameplate when one has 67 year old eyes Will be 68 year old eyes pretty soon (9/9/2012).
67 year old eyes cannot make out stainless steel w/shield reveal mouldings. Is the grille painted? Looks that way to my 67 year old eyes.
__________________
  #7 (permalink)
Old 07-26-2012, 12:40 PM
lol, if thats the only thing going wrong then your doing fairly well sir. I just hope to retain half the knowledge you have when I'm your age.. (24 here)
  #8 (permalink)
Old 07-26-2012, 12:49 PM
Another question.. Is there a web site I can see how many trucks were made in '61 and then narrow it down with how many were made with those options.
IE - Only 12 made in 1961 in Reangoon Red with the 292, 9", 3spd, and Custom Cab..
I hope this makes sense..
  #9 (permalink)
Old 07-26-2012, 01:39 PM
Ford Parts Guru
2013 Ford Escape
Next to no info is available, regardless of what website you're using.
IE - Only 12 made in 1961 in Rangoon Red with the 292, 9", 3spd, and Custom Cab.
There is no way to find this out!
It makes sense. But what does not make sense is: Owners/enthusiasts of 1961/66 (all) FoMoCo vehicles (except Shelby's) are up the proverbial creek without a paddle!
FoMoCo THREW AWAY ALL THE RECORDS decades ago.
All that's available are the scant production figures, kept for the entire auto industry by R. L. Polk & Co.
These production figures do not break down Custom from Standard Cabs, how many came with what engine, trans, what color they were and et cetera, et cetera, et cetera!.
From the Standard Catalog of Light Duty Ford Trucks / krause.com / ISBN: 0-87349-411-3 / 1961 F100 Unit Body Pickup production figure: 62,410
This is IT! No breakdown is available as to short/long wheelbases, or any other jazz.
And, in the late 1980's, FoMoCo was planning to THROW AWAY all the 1967/79 records. Kevin Marti (martiauto.com), a Mustang "nut" in Phoenix AZ found out...and got ALL OF IT!
__________________
  #10 (permalink)
Old 07-26-2012, 02:20 PM
Thanks again for all your help Bill!! You have been VERY informative! I will be sure to keep you guys up to date on the progress.
  #11 (permalink)
Old 07-26-2012, 02:40 PM
arctic y block's Avatar
arctic y block arctic y block is offline
Old School
1962 Ford F-100
arctic y block has a spectacular reputation.arctic y block has a spectacular reputation.arctic y block has a spectacular reputation.arctic y block has a spectacular reputation.arctic y block has a spectacular reputation.arctic y block has a spectacular reputation.arctic y block has a spectacular reputation.arctic y block has a spectacular reputation.arctic y block has a spectacular reputation.arctic y block has a spectacular reputation.arctic y block has a spectacular reputation.
Nice Truck. Looks like a CC to me. There is a Uni category on here. At the very top of this page click on forums and find it. There is a thread there for registering your Uni. Guy has done a lot of research and is listing all he can fined to try and get an idea of how many are left
__________________
85 XLT Bronco 351W HO 4V Dual Pipes 33X12.5 BFG's
62 Uni 390 C6 Custom Cab Not Yet Sold
Looking to buy a 48/50 F Anything If ya have one contact me.
Don't just Modify it Fordify it
  #12 (permalink)
Old 07-29-2012, 11:49 PM
429unibody's Avatar
429unibody 429unibody is offline
2010 Ford F-150
My Garage
429unibody is gaining momentum as a positive member of FTE.
Just for chitts and giggles look around and see how many shortbox 61 Mercury uni's you can find.......besides mine
  #13 (permalink)
Old 07-30-2012, 12:44 AM
jacks61ford's Avatar
jacks61ford jacks61ford is offline
jacks61ford is starting off with a positive reputation.
I just want 61 merc chrome grill hood spears hub caps and tailgate lol I want a clone
  #14 (permalink)
Old 08-01-2012, 06:59 PM
FTE Membership FTE Membership is offline
Internet Brands
FTE Membership is gaining momentum as a positive member of FTE.
Try the VIN decoder on the forum: VIN Decoder - Ford Truck Enthusiasts Forums
  #15 (permalink)
Old 08-02-2012, 05:26 AM
Ford Parts Guru
2013 Ford Escape
Quote:
Type the OP's 11 digit (character) VIN: F10CD140504 into this VIN decoder and you'll get this message: Please enter a valid VIN of 17 characters.
1948/80 all trucks, 1961/80 Econolines, 1966/80 Bronco's have 11 digit (character) VIN's. 1981 thru today, have 17 digit VIN's.
Post 2: OP's VIN and Warranty Plate (pic in post 1) codes decoded.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
