fuel pump question - Ford Truck Enthusiasts Forums
fuel pump question
Old 07-26-2012, 11:54 AM
max4hdmatt max4hdmatt is offline
max4hdmatt is starting off with a positive reputation.
fuel pump question
I am in the process of buying a 05 6.0 and it needs a bigger fuel pump. It has a bigger turbo and 190cc injectors. I was looking at the air dog raptor 150 gph pump. In wondering if that's going to put out enough fuel for the truck or do I need one that puts out more fuel? It has approx 700hp. Thanks
Old 07-26-2012, 08:28 PM
Any advice anyone?
Old 07-26-2012, 08:33 PM
BLADE35's Avatar
BLADE35 BLADE35 is offline
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
you need a regulated return and get rid of the Dead Head system it has
Air Dog or Fass or something I beleive the guys use
do a search on here should get some good info on it
Old 07-27-2012, 02:37 AM
Fulthrotl Fulthrotl is offline
Fulthrotl has a great reputation on FTE.Fulthrotl has a great reputation on FTE.Fulthrotl has a great reputation on FTE.Fulthrotl has a great reputation on FTE.
Quote:
Driven Diesel 6.0L Regulated Return Kit
$665
that is a lot of fuel.... 700 hp... ?
how'd it manage to run with the OEM setup?
Old 07-27-2012, 05:01 AM
npccpartsman's Avatar
npccpartsman npccpartsman is online now
npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.
I'd like a few more specifics on the turbo and injectors before I make a recommendation on fuel. How did you arrive at the 700 hp number and is that flywheel or rear wheel HP?
Old 07-27-2012, 06:24 AM
dillehay's Avatar
dillehay dillehay is offline
dillehay is starting off with a positive reputation.
I would say use extreme caution buying anything that was previously modified.
There could be alot of abuse to that engine hidden behind those shiny parts.
If you want to build a rig find a clean stock or at least mostly stock truck and start there.
You may be happy with the truck and its performance at that level.
Extreme mods do extreme (expensive) damage.
Good luck
Old 07-27-2012, 08:46 AM
Quote:
Good luck
the technical term is called "tinky.... tinky.... BANG!"
Old 07-27-2012, 09:25 AM
MC5C MC5C is offline
MC5C has a very good reputation on FTE.MC5C has a very good reputation on FTE.MC5C has a very good reputation on FTE.
I did a little reading, and 600 hp appears to need 250 cc injectors and a big shot of nitrous. Fire ringed heads, but the bottom end appears up to it. No one was really talking about an honest 700 hp, but you would definitely need a lot of turbo, and probably bottom end work.
Brian
Old 07-27-2012, 09:43 AM
dillehay's Avatar
Quote:
Good advice to live by
Old 07-27-2012, 10:07 AM
Yea 700 hp is a round about number. at the wheel its probably around 550 at most. its actually belongs to a good buddy of mine and i have seen the whole life of the truck and its been taken care of. it runs fine with the oem. but you gotta drive it like an 80 year old grandma or it will blow injectors after a couple months. so its sounds like after doing some research im going to need a bigger fuel pump and regulated return? correct me if im wrong. i also appreciate the information everyone.
Old 07-27-2012, 10:17 AM
also im obviously going to need bigger fuel lines to accomodate for the bigger fuel pump.
Old 07-27-2012, 10:47 AM
'm kay.... you can throw money at this all day long....
as has been said here, one of the stronger 6.0 participants
here is tex, at 500 hp. he recently posted what he's done
to run 200k miles without a tinky, tinky, bang. it's substantial.
the tranny mods were $5k.
you might want to talk to him.
let's put this in perspective. a diesel putting out
100 horsepower per liter in a street driver is a bit nuts.
i have a sport bike i enjoy. it's 1,300 CC, and 180 RWHP. to get that is
no small feat of engineering, and part of it requires the vehicle be moving
above 150 mph, as the static head intake pressure at that speed is 6 pounds
boost from the air intakes, and it takes above 9,000 rpm to do it. it won't
produce that on a dyno... maybe 130-140 on a dyno without the airflow.
so... 100 hp per liter, more or less. you want to get 15% more than that
from a light truck engine with a stock long block? with stock crank,
rods, and pistons?
how long do you expect this "daily driver" to last?
go look at tex's build sheet, and add all parts he has that you don't.
that's been proven for 500 hp.
Old 07-27-2012, 12:08 PM
Its got a suncoast tranny and worked pistons and aftermarket crank. its got everything it needs minues the fuel system. all im trying to do is get info on the fuel system. i know motors and transmission decently i just dont know much about fuel systems.
Old 07-27-2012, 06:01 PM
metmop metmop is offline
metmop is gaining momentum as a positive member of FTE.
Most of the people crusing this forum run mostly stock (or lightly tuned) trucks for towing or various other work. While I am not saying you won't get the answer here... you may want to consider posting this thread in either the offroad (they modify trucks a lot) or the fuel section of FTE. Either way Good Luck. One of the things I love about trucks is their versatility. One of the things I hate about humans is the way they screw up their perfectly good trucks
Old 07-27-2012, 06:42 PM
Where did the crankshaft come from? I've never seen or heard of an issue with the stock crank and I know of one with 1000+ HP (rear wheels). I'd also like to see the dyno sheets for the horsepower or is it just an estimate? What tuner and whose tuning is it running?
Metmop: There are more than a few of us running (or have run) some fairly heavy modifications on the 6.0.
Auxillary Tank as a Pump Station? sum_weirdo 1973 - 1979 F-100 & Larger F-Series Trucks 1 02-08-2012 09:04 PM
Fuel pump/filter/pressure regulator questions. Myfreeford Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 5 01-11-2012 11:07 AM
How much Fuel Pressure for carbed 460? gittinwidit Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 5 11-16-2006 03:18 PM
Fuel System Upgrade? mike460 1987 - 1996 F150 & Larger F-Series Trucks 0 05-02-2005 10:28 PM
Engine running lean Fasterhorses 1997 - 2003 F150 5 09-23-2004 01:41 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
