You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I just used trusty fleabay to purchase a SNATCH strap. An Ironman brand 9m x 100mm 11,000kg.
Reading the instructions it says that ideally the capacity of the strap should be 2 to 3 times the weight of the LIGHTER recovery vehicle. So the 11,000kg strap will get good only if I'm being pulled out by another F250, or something bigger.
If I'm going to get into the habit of being rescued by Cruisers I should have opted for the 9,000kg strap and saved a few bucks.
Any thoughts anyone, other than don't get stuck in the first place?
Do 4WD'ers take a few straps of different capacities in their rescue bags?
__________________
Mods done: lots of cheap mods (Hutch, IC boots, plenum inserts, IH uppies, HPx, AIH delete, EBPV delete, hi flow outlet, CCV mod, OCR, Superchips, Zoodad, 6637, 4" TB exhaust, JW valvebody, coolant filter, FRx, '05 HD lights with switch bypass relays, B100 ready fuel system)
Mods NOT done: big oil, big brakes, big turbo
Next mods: ? tuner, G2WW (on the shelf), alloy diff covers
Australia: where Mechanics use spanners and Plumbers use wrenches...
__________________
Brian
03 F250 XLT LB . Full Engine build with all the goodies. Tuned by Matt
- cant wait until my motor blows so I can blame someone else - join the Australian Chapter here-Join Chapter
The point is what happens if you get stuck and the guy towing you out is driving a lightweight? The light vehicle is not going to stretch the 11,000kg strap and you might be stuck until another F250 (or larger) comes along....
Latest minor mod was to put some recovery points on the back of my truck The Ironman ****** strap instructions state 'DO NOT USE A TOW BALL as a recovery point'.
I used trusty flea-bay to source 2 10,000 lb recovery hooks at $22.50 + $7.50 postage each. Have fitted them up to the tow bar side plates which are themselves bolted to the chassis with 4 very large bolts each side:
__________________
