You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
What did you end up paying to get it freighted over?
__________________
Mods done: lots of cheap mods (Hutch, IC boots, plenum inserts, IH uppies, HPx, AIH delete, EBPV delete, hi flow outlet, CCV mod, OCR, Superchips, Zoodad, 6637, 4" TB exhaust, JW valvebody, coolant filter, FRx, '05 HD lights with switch bypass relays, B100 ready fuel system)
Mods NOT done: big oil, big brakes, big turbo
Next mods: ? tuner, G2WW (on the shelf), alloy diff covers
Australia: where Mechanics use spanners and Plumbers use wrenches...
Looking good Reg. Where did you get the shockers from ???
__________________
Brian
03 F250 XLT LB . Full Engine build with all the goodies. Tuned by Matt
- cant wait until my motor blows so I can blame someone else - join the Australian Chapter here-Join Chapter
G'day Simon,
Not sure mate. I got three items in the one package. Total freight was US$133.55. The Diff Cover was US$224.81 and the other two items were only US$44.69.
They had little weight and size. So I guess the bulk of the $133 was for the cover. Not a cheap exercise, but that is freight all over. If you want it ya pay to get here .
Of course it's got a bit to do with other blokes 'Admiration Factor'
Cheers,
Reg
__________________ Aussie spec 2005 (US 2003) F-250 SD 4x4 7.3Ltr Powerstroke: PHP FU2 6 Pos’n Chip,6 x ISSPRO Guages, AIS Intake, Zoodad, Hutch'd n’ Harpoon'd. Cowl Hood, AIH Delete, CCV, RiffRaff FRx,HPx,OCR, JWVB. ARB Air Lockers Front & Rear,V10 Tranny cooler + Stock Tranny cooler, ARB Bull Bar. Long Range Fuel Tank,VMS in Dash GPS Nav.OME Suspension & Dual Tower Shocks, MOOG Ball Joints. GVWR (GVM) Upgrade to 5,000Kg (F350+).
G'day Brian,
They're Old Man Emu Nitros from ARB. The Part# for rears are 2 x 179 and 2 x 180.
I've got the 178 s on the front. Not standard for 2.5" lift of the F-Trucks due to mine having the Dual Tower brackets. That tends to shorten the mounting distance between the top and bottom mounting points.
They seem to do the job and I've been over some bloody rough country with them and loaded towing 3.5T.
Cheers,
Reg
Grab us a pic of ya dual tower shocks m8. In particular the top and bottom mounts
__________________
Brian
G'day Brian,
Sorry mate can't help ya there at this point in time.
I've just joined the ship on Wednesday and won't be back home until the 7th of Sept.
I'll get a good series of pics then and post em.
Cheers,
Reg
No wuckas m8. Safe sailing, see ya when ya get back
__________________
Brian
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
