General crankcase vent question - Ford Truck Enthusiasts Forums
Old 07-26-2012, 01:07 AM
stickbow9 stickbow9 is offline
stickbow9 is starting off with a positive reputation.
Hello all. I am in the process of reading and learning every night from you folks and am feeling more confident daily. So I was reading a few threads about crankcase ventilation and have a question. I have a 77 F250 highboy with 351m with some mods that PO's did (weber/carter carb & intake manifold)and I don't know if it is actually 351 or 400. Anyways, the passenger valve cover has an adaptor in the top with a hose that used to go to the air filter cover. I have an Edelbrock air cleaner and the hose that comes out of this passenger side valve cover has a length of all thread plugging it up. There is also what appears to be a slight leak at the rear main seal area....SO HERE IS THE QUESTION-Without the proper crankcase breather, will there potentially be enough pressure to cause a leak at the rear main seal?
If so, would replacing this plugged up hose with a breather help the situation. Thanks in advance.
Old 07-26-2012, 01:42 AM
hasteranger's Avatar
hasteranger hasteranger is offline
hasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud of
I have read that yes, it will generate enough pressure to push oil past the seal. youre better off leaving it open than plugged. Mine is open right now, but I'd like to plumb it back to the air filter.
Old 07-26-2012, 08:29 AM
fmc400's Avatar
fmc400 fmc400 is offline
MSEE
fmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud of
Short answer: YES. Proper PCV system is crucial to engine life for many reasons, seal integrity being one of them.
This is not to say that re-routing the PCV system will fix your rear main leak because it probably won't.
Old 07-26-2012, 11:25 AM
mark a.'s Avatar
mark a. mark a. is offline
mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.
I would at least remove that piece of all thread, you don't want that hose plugged off.
Old 07-26-2012, 11:55 AM
Thanks for the confirmation. I am going to try the breather first and then possibly change the two piece rear main with it in the truck. Hope it goes well, but the leak only happens after long hot drives that I noticed and is not much at all.
Water in the oil and crankcase pressure? donerico 1973 - 1979 F-100 & Larger F-Series Trucks 12 02-09-2017 12:37 PM
Crankcase breather missing part? ford300fan 1987 - 1996 F150 & Larger F-Series Trucks 3 02-06-2017 09:14 PM
6.0L - Difference between model years bismic 6.0L Power Stroke Diesel 34 12-29-2016 12:18 AM
Excess crankcase vacuum causing whistling on 5.4 V8 3 valve eallanboggs 2004 - 2008 F150 11 07-08-2016 07:54 PM
7.3L PCV Re-Locate Questions....... JoeBoost 1999 to 2016 Super Duty 3 05-11-2003 05:45 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
