94 F150 e4od transmission problem
Old 07-25-2012, 03:52 PM
CCope94's Avatar
CCope94
CCope94 is offline
Just put a new e4od transmission in my truck. it is stuck in either 3rd or 4th gear and will not shift. i just replaced the nuetral saftey swaftey switch and its still stuck. can somebody please help??
Old 07-25-2012, 03:56 PM
Lead Head's Avatar
Lead Head
Lead Head is offline
The electrical connection is not seated properly. You'll get 4th in drive, and 2nd in 1 or 2.
Old 07-25-2012, 09:45 PM
CCope94's Avatar
CCope94
CCope94 is offline
the neutral saftey connector is brand new. but the connector on the other side of the tranny is not connecting right, could that be the problem?
Old 07-25-2012, 10:19 PM
Lead Head's Avatar
Lead Head
Yes. That is the main connection that controls the transmission. Without it, it will default to 4th gear.
If you put a new E4OD, that is your problem. They changed the connector in '95. Your choices at this point are:
1. Swap in an older transmission
2. Change out the solenoid pack to one from an older transmission
3. Cut the connector off your truck and splice on the new style connector.
Old 07-25-2012, 10:30 PM
burnout400m's Avatar
burnout400m
burnout400m is offline
I would say defiantly.
Old 07-25-2012, 10:31 PM
CCope94's Avatar
CCope94
CCope94 is offline
how do you tell what plug to get?
Old 07-25-2012, 10:35 PM
burnout400m
Well it sounds like there are only two different ones, 94 and down and 95 and up. Sounds to me like your truck has a '94 plug and the trans has a 95 plug.
You could always snap a pic of the plugs on your truck/trans to compare when you hit the parts store.
Old 07-25-2012, 10:37 PM
CCope94's Avatar
CCope94
CCope94 is offline
Thats what ill have to do. Thanks guys! thatll save me alot of time! ill post if i have anymore questions.
Old 07-25-2012, 10:38 PM
burnout400m
This is why I bought a C6. LOL
Old 07-25-2012, 11:28 PM
CCope94's Avatar
CCope94
CCope94 is offline
thats what i should have got, this will be my 3rd e4od.
Old 07-26-2012, 12:08 AM
burnout400m
The E4OD is actually a C6 with overdrive and electronically controlled. If I were replacing an E4OD I'd just take the hit and find a reputable tranny shop to upgrade it and make it more durable. Actually I did do that exact thing with the 700r4 in my '84 K5 blazer. A built E4OD will cost more but will last as long as anything.
Old 07-26-2012, 08:54 AM
subford's Avatar
subford
subford is offline
Not sure why everybody is jumping on the 94-95 plug change for the diodes.
If you have a 1994 and you got a transmission for/from a 1994 then you will have the right plug on your harness and transmission.
The problem with that plug is the heat from the exhaust causes problems right where the wires go into the back of the plug and the wires brake off. You should have a heat shield bolted to the transmission at that point.
CCope94
61
08-13-2012 01:27 PM
pro70golfer14
10-12-2009 07:01 PM
javi2001
09-08-2007 03:18 PM
Quick Reply: 94 F150 e4od transmission problem
