Transmissions for 1986 Ford F150 - Ford Truck Enthusiasts Forums
Old 05-11-2003, 11:21 AM
FatzFord FatzFord is offline
FatzFord is starting off with a positive reputation.
Cool Transmissions for 1986 Ford F150
I'm sure this has beed discussed many times through the years but I need a refresher. I have that 5 ltr in a Ford F150 2x4. Right now it has a borg warner 4 speed in it. I need better proformance off the line. and a better over all gear ratio. I plan on switching out the rear end. What types of configurations are recomended? Is it true that theres a mazda tranny that will retro fit? Its turing out to be a sleeper/racer and I'd love to continue down that road. Thanks in advance,
fatZ
1986 F150 5 lrt efi. Droped 2 " in the rear, lifted 2 " in the front. California legal shorty headers "Stillen front cross drilled rotors. See pics..
Old 05-11-2003, 12:07 PM
steve83's Avatar
steve83 steve83 is offline
steve83 is starting off with a positive reputation.
http://www.motivegear.com/tech_info/...nny_guide.html
The Mazda M5OD-R2 is considered weak and doesn't have the granny gear that your BW T-18/19 does.
http://www.novak-adapt.com/knowledge...on_gateway.htm
Old 05-11-2003, 02:06 PM
Arrow Transmissions for 1986 Ford F150
I also hear that the AOD automatic tranny from a mustang of the same year will retrofit..Heard anything about that?
Old 05-12-2003, 08:39 PM
steve83's Avatar
Didn't know you were interested in slushboxes. I'd use a truck AOD before a car one.
http://www.baumannengineering.com/
Old 05-12-2003, 10:21 PM
really want you to tell me is what you think a good tranny/rear end combo would be in my truck. It seems like the 5 ltr really picks up but the high gears of the t19 keeps it back..Enlighten me please..
Fatz
Old 05-12-2003, 11:57 PM
steve83's Avatar
They're not really interdependent. Pick one and get the other to match your first choice. It depends on too many things for me to even make a recommendation:
How much do you want to spend? How do you want it to drive? How much abuse are you going to put it to? How much do you want to spend? How fast do you want to go? How slow do you want to go? How much do you want to spend? How much maintenance are you willing to do? How much work are you willing to do to install it? How much do you want to spend? What are you going to do with the truck? How much are you going to tow? How much do you want to spend? (Get the idea? )
Your interests are too different from mine for my opinion to be useful. It seems to me that you're trying to build a sports car out of a truck. I just don't think that's a good way to spend time, money, or sweat. If I want to go fast around curves (faster than I can now ), I'll build a Mustang.
I'm sure plenty of other people who share your interests will post some good info for you, but I've told you about all I can.
Old 05-13-2003, 10:42 PM
err how much money will it take ..;-)
Old 05-13-2003, 11:25 PM
mustange70's Avatar
mustange70 mustange70 is offline
mustange70 has a good reputation on FTE.mustange70 has a good reputation on FTE.
How getting a toploader 4 speed (wide ratio) for you truck along with a set of 3.50s or 3.73s. Top end won't be overly fast but the toploader will bolt right in (it did in mine but i have a 351 in my truck). You will have to take the center piece out of an automatic and cut it to fit the shifter. I have 3.0:1 in my truck for gears, for the current motor it needs more gear but it will be getting more motor in a short while.
Old 05-14-2003, 10:07 PM
What kind of tranny is this and how is it configured? does it shift from the floor like the old t19?
Tnx for the reply
FatZ
Old 05-15-2003, 12:43 AM
mustange70's Avatar
What it is is its a 4 speed for used in the muscle car era cause it can handle the power that some people would put in their cars, like my dad had a 429 boss stang with 600hp and it was stock with the exception of a drag clutch. Go check out David Kee Toploaders .com, if that doesn't work do a search on either that name or toploader transmissions and you will find one. They cost quite a bit to buy brand new so i would get all the info and go get one out of a junkers and recondition it or you can usually find one at a swap meet.
Old 05-16-2003, 12:06 PM
f100beatertruck's Avatar
f100beatertruck f100beatertruck is offline
f100beatertruck has a very good reputation on FTE.f100beatertruck has a very good reputation on FTE.f100beatertruck has a very good reputation on FTE.f100beatertruck has a very good reputation on FTE.
You could try a Tremec 3550 or TKO designed for a mustang with a mid-shift kit. Check out www.hanlonmotorsports.com for info on the Tremec and mid-shift kit. I'd run a 3.50 - 4.11 gear in the rear because the Tremec has a 32% overdrive.
If cost is an issue, your best bet would be to find a used toploader trans, or if you get lucky sometimes the tremecs turn up used in the mustang crowds. Expect to spend $600 - $800 for a used tremec.
Old 05-16-2003, 08:23 PM
I'm checking out all your leads, Money is not an issue and I'm happy to see I'm not alone in my endevor
1986 F150 Stepside EFI 302 parts truck fepowerguy8 Ford Truck Parts for Sale 19 07-23-2015 11:42 AM
New kid on the block. 1995 F150 XL free1986 1987 - 1996 F150 & Larger F-Series Trucks 28 07-08-2014 07:08 AM
1986 ford f150 4x4 shifting pattern 1986 ford blue f150 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 10 08-24-2011 01:24 PM
1986 Ford F150 4x4 4x4FordGirl 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 11-03-2010 01:05 AM
How to tell what axle? RabidJade 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 9 09-24-2003 11:33 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
